hi im having dificulty trying to restore services saved in temp folder i downloaded north lanarkshire services and bouquets ok found tar. gz file fxp into temp folder rebooted the box went into user fetures menue selected services restore tried bouquets only showing favorets list of channels from a to z dont know where im going wrong i done a scan on dw.2 image prior to attempting fxp transfer to temp folder should i have transfered the services and bouquets over to the box with a freshly flashed image or maybee i should have unraped the tar.gz file before puting into temp folder help!! anyone
services restore from feature menu prob!
anything you place in /tmp will be removed when u unplug the power to your dreambox buddyhi im having dificulty trying to restore services saved in temp folder i downloaded north lanarkshire services and bouquets ok found tar. gz file fxp into temp folder rebooted the box went into user fetures menue selected services restore tried bouquets only showing favorets list of channels from a to z dont know where im going wrong i done a scan on dw.2 image prior to attempting fxp transfer to temp folder should i have transfered the services and bouquets over to the box with a freshly flashed image or maybee i should have unraped the tar.gz file before puting into temp folder help!! anyone
best bet is to ftp the tar.gz over then use blue button menu to extract and install upon reboot your services and bouqetts should be there
cheers
osborne82 -
services resrore from feature menue prob
hi osbourne thanks for advice!! i will start with a freshly flashed image d.w 2.o connect to pc with crossover power on dreambox transfer file into temp folder with fxp then close down fxp leaving on the dreambox how do i use the blue button from there do i have to use a scart to tv screen to see blue button option from the feature menue or can i do this via pc monitor thanks bingo!!!! all is working superb youre 100% correct great info got me sorted top guy!!thanks againComment
