DK v1 image problem
  • Dowie
    • 119
    DK v1 image problem
    Hi all
    Got a strange one here! Ive an eagle and a dream clone and when i upload the DK image to both boxes the boxes go into a reboot cycle after flashing if I put the DW image they both bootup tried to reflash 3 times and re downloaded the image but the same thing happens!
    Any help would be great!!
    Dowie
    WAS MAR 2009 OCT 2012 AND NO PRICE INCREASE
  • satman
    • 736
    Originally posted by Dowie
    Hi all
    Dowie
    Have you tried doing a flash erase before flashing it?,, ,and then proceed to flash
    boom!
    • Dowie
      • 119
      Hi Satman
      Actually no i havent it just seem strange that its only this image thats affected DW and others are fine!
      Does Flash erase not kill the bootloader?
      Dowie
      • satman
        • 736
        Hi Satman
        Dowie
        no,, use dreamup and do a flash-erase first( conect up by serial and connect and click flash erase),,,,,,,,
        then try and reflash it,,,
        and no, your flash erase aint nothing to do with bootloader that aint part of the flash memory
        boom!
        • Dowie
          • 119
          Cool
          Cheers Satman ill give it a try tonight!!
          • Dowie
            • 119
            Oh no guess what!!
            3:18:36 PM box type: DM500
            3:18:49 PM Ping result: OK, box is alive and speaking to us ;-)
            3:18:55 PM erasing complete flash (without bmon stage of course)...
            3:19:05 PM ERROR, flash-erase failed, box will be unusable now!!
            What do i do now
            • smirnoff_rules
              • 8603
              strange .. can u connect to ftp programe when its working on dw . if u can l send an image u can install in tmp folder and u can do a manual update
              • Dowie
                • 119
                I can flash the box now but it does nothing! Bricked??
                Dowie
                • smirnoff_rules
                  • 8603
                  turn off the box and the plug send your firmware over and then turn on at the plug again ,
                  • Dowie
                    • 119
                    Ive sorted it i think!!!
                    I started from scratch again!!
                    Erased flash as Satman advised
                    Sent image over to box
                    Seems to be working now
                    Thanks for you help anyway matey!!
                    Dowie
                    • Devilfish
                      Administrator
                      • Feb 2008
                      • 7872
                      If you have any problems with dreamup or images, do a flash erase TWICE (I know sounds silly but works) then download the firmware from the dream multimedia site and flash that. Once you have a working base, you can flash whatever image you want.
                      There are also many different versions of dreamup, the dream multimedia site only shows the latest but a google search usually gets you a few older versions which can sometimes help.
                      • challah
                        • 242
                        my guess is the image file is/was still rared/zipped when you tried to flash
                        dreamup will flash the file but it will not work
                        • Neil
                          • 194
                          Is that goos advice with all the clone boxes about. Does the latest Dream image not screw up the boot loader of clones?
                          I can't help thinking that new versions of DreamUp might be used to remove the boot loader from clone boxes as well soon. It might be a good idea to stick with a version from before the clone bombs started.
                          500c, 600c, 7025+cc, 7000s with a 1m steerable dish
