Backup image onto new box with Dreamup
  • gizzi
    • 15
    DM500 Backup image onto new box with Dreamup
    I've a working 500c and have a new 500c on the way for a friend. Can I simply use DreamUp (with a Null Modem Cable) to take a backup of the working box. Then connect the new 500c and flash it using the backed up image?
    Just making sure before I bugger up my box!
    Thanks in advance!!!!
  • a1gunner
    • 169
    yes m8 just backup ur imaige and flash straight to box m8 everything will be like your own box
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      When you're flashing your new box with dreamup, at the part when it asks if you want to flash erase during process, choose NO because if you choose yes, it will erase all your keys, services, bouquets, etc. and it will be as if it's a standard image.
      This is a common mistake when flashing a backup image with dreamup. People think it's ok until they reboot the box and it doesn't clear channels or contain key files, etc.
      • bob114
        • 192
        hi
        also you can back up your image then flash it to the other box
        using Guide: Flash and Backup an Image via Telnet in cable dreambox section I find this way a lot faster
        hope this may help
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          The telnet method is definitely much quicker, I prefer to use this method.
          Or, if you're using the DK image, there's an option to backup and flash images in the User Features menu (yellow button). All you need to do then if ftp the images to/from the box.
          • gizzi
            • 15
            Thanks guys - Will give the dreamup method a go first and see how I get on.
            Have to says guys the response that people give on this forum is first class!
            Keep up the good work!
            Cheers!!!
            • macjst35
              • Oct 2008
              • 113
              Img file
              Hi all i've backed up dk 1.1 image using dreamup problem is i cannot flash it because dreamup program can't find it on my desktop is it because the file type is file not IMG file if it is how could i change the type of file to Img file any help would be cool .
              • garymce
                • Jun 2009
                • 11
                I had the same problem, it's just that when DreamUp backs up the image, it doesn't append the file format if you don't specifically type it. All you need to do is rename the file and add .img to the end of it, it'll work fine.
                • jicube
                  • Sep 2009
                  • 4
                  just ordered a box and have a back up image (so all i have to do is flash that image i.e just connect and press flash?)
                  • avu45
                    • Jun 2009
                    I must say Thank you for your usefull advice. I have followed your advice and I have flashed my box and its working fine. Thank you again
                    • kewlman
                      great info. thanx guys. very helpful.
