problems mounting for recording on DK v1
  • vambo
    • 9
    has anyone managed to get pc recording working on vista 64bit everytime i try to mount cifs as advised in sticky i get:
    CIFS mount 192.168.13/recordings/hdd' FAILED!
    im not sure the box is seeing my shared folder?
    any other guides out there?
  • osborne82
    Dreambox Guru
    • 133
    is that the right ip addy buddy ? 192.168.13 ?
    cheers
    osborne82
    • vambo
      • 9
      typed it wrong thats all sry.
      my router is:192.168.1.1
      my pc:192.168.1.3
      dream box:192.168.1.4
      cant get to the bottom of this i have tried lots of things, the dbox conects to net and i can ftp and use engima web page...
      • osborne82
        Dreambox Guru
        • 133
        my pc:192.168.1.3
        np just thought id ask as sometimes the smallest things get overlooked heheh
        not so sure then buddy can u try mount via the webinterface also double check that your share on pc is corectly named and file sharing is enabled, also do u have a password on your pc ?
        cheers
        osborne82
        • Gueststar
          • 17
          'new movie folder'
          Hi there vambo,
          I had the same problem but on XP managed to see the shared folder by
          FTPing to the box then look in the /hdd folder there should be a folder named
          'movie' if there isn't just right click and 'Make new folder' and name it movie
          Then go back to your mount settings and configure it to this 'movie' folder.
          Hope tis helps only just did this myself last night 17-06-08
          Good luck
          ORY
          • vambo
            • 9
            that folder is there with movies inside of it, i can see it in fxp but i still get fail when i mount. i have (hopefully)attached pics of settings.
            i have removed my system password my pc log in is vambo
            i have created a folder in: c:\recordings inside of this folder is the movies folder all of which are shared (right click sharing)
            my network address is VAMBO-PC
            getting ready to throw it out the window now! anybody want spares?
            • smirnoff_rules
              • 8603
              l have only ever got this when the ip is wrong
              there are multiple ways. one way is to go to start>run> type cmd then enter and then type ipconfig this will show you your ip address among other things. you can also go start>all programs>accessories>communications>netw... connections, then right click on your connection and go to status and look under the support tab
              • kagon
                • 140
                I thought Vista was an absolute bastard with CIFS shares like this and didn't allow passwordless logins anymore though? Can you mount it from another system with:
                \\192.168.1.3\recordings
                I'd make sure you can a) mount it from another system and b) ensure you have a valid username/password combination working before you attempt to get things mounting on your Dreambox.
                • Devilfish
                  Administrator
                  • Feb 2008
                  • 7872
                  I remember something about IPv4 and IPv6 with Vista.
                  Try setting the properties of your network card in the PC to IPv4.
                  • osborne82
                    Dreambox Guru
                    • 133
                    try this buddy
                    1. Click Start, type: "CMD" (without quotation) in the Start Search bar
                    2. Right click Command Prompt in the search list and click Run as
                    Administrator
                    3. Type the following command and press Enter:
                    netsh interface tcp set global rss=disabled
                    netsh interface tcp set global autotuninglevel=disabled and reboot
                    now telnet into your dreambox and enter
                    mount -t cifs -o user=vambo,password=******//192.168.1.3/recordings /hdd
                    change **** for your pass on pc
                    hopefully that should do it if not try as devilfish suggested and also disable IPv6
                    cheers
                    osborne82
                    edit forgot to say telnet is disabled by defualt with vista so either enable it or use putty for telnet
