SpeedUP your Stream with: ShowTime Player PluS Ultra Light Edition V1.0
  • yassinov
    • Jun 2009
    • 78
    ShowTime Player PluS Ultra Light Edition V1.75 Ready
    Install Steps:
    Features:
    -Fast Audio/Video Streaming From Dreambox
    -Fast Channels change during streaming
    -Change Audio language faster (IF CH Enable Audio LNG Change)
    -comfortable interface in various modes Aspect ration / diffrent sizes/Modes
    -comfortable Audio/Volume interface in Full Screen mode
    New Updated :
    -Added Video Mode Switcher (Normal/Desktop)
    -Light Interface Work
    -ShowTime Player Plus Home Location
    -Video mode optimized
    Enjoy The Show !
    Best Regards , yassinov
  • alwan 2009
    • Sep 2009
    thanksssssssssssssssssss
    • oldeno
      • Aug 2009
      • 274
      It's great!! Thank you very much.
      I am using it now,so far so good.
      • kiteboy
        • Aug 2009
        • 26
        Doesnt work for me properley....same as the full version .........seems to work ok on some channels and streams nicely however get the following in the dos box when it doesnt stream at all for example on sky sports 1................. PRESS ENTER TO GO FULLSCREEN FOR 3 SECONDS
        libdvbpsi error (PSI decoder): TS discontinuity (received 9, expected 0) for PID 0
        Not sure if it means anything??
        tried restarting the program so that it starts up on the channels that do not stream and again it doesnt work....try the same on BBC1 for example and streams straight away no probs......any ideas anyone???
        Edit: Just gave it a bit of time and tried again on sky sports and it streams......seems like as long as you dont switch over too much its ok
        Somettimes it works sometimes it doesnt
        ie get the following error also
        D 32
        libdvbpsi error (PSI decoder): TS discontinuity (received 12, expected 0) for PI
        D 32
        D 32
        D 32
        D 32
        D 32
        D 32
        D 32
        D 32
        • yassinov
          • Jun 2009
          • 78
          D 32
          D 32
          D 32
          D 32
          D 32
          D 32
          D 32
          D 32
          D 32
          Since the PID answer is not x00 then must work !
          Wich image version you use ?
          Btw : Sw tested with Gimini & Pli-jad versions work perfect !
          • kiteboy
            • Aug 2009
            • 26
            Im using the version on this site the DK 1.1 image i think it is
            Never used anything else for the dreambox 500c
            Just noticed I get the above output even when it works (seems to always work on BBC1) odd as
            Thanks by the way looks great when it does work
            • Duall
              • 38
              i can click on a channel get this in the cmd box
              D 32
              and i very rarely get the full screen and if i do i get lines of colurs...
              • yassinov
                • Jun 2009
                • 78
                D 32
                From VLC Settings menu go to Video/Output modules/Advanced Options & try disable "Use Hardware YUV -> RGB Conversation" & look for another choice from "Name of desired display device" !
                • kiteboy
                  • Aug 2009
                  • 26
                  Only default under the name of desired display device so cant choose anything else
                  tried disabling the YUV>>RGB conversion but nothing happens VLC doesnt even open
                  • yassinov
                    • Jun 2009
                    • 78
                    Please recheck with the new Update ! your problem is strange a little coz never reported before !
                    • kiteboy
                      • Aug 2009
                      • 26
                      OMG this so far seems to work for me!!!! Im amazed ...so far so good thanks yassinov
                      Arrgggh It just froze and wont start the TV now....ill get back
                      • kiteboy
                        • Aug 2009
                        • 26
                        Still seems very intermittant for me at least -has anybody else had any luck...I cant get working again even after rebooting everything
                        just got going again but cant switch over at all - just doesnt work
                        Still seems to me like bbc works far better than anything else but that maybe me
