I have used this before and got all channels, but then returned to virgin media box as some channels were freezing, I have now tried to plug my dreambox back in and all of the channels have gone and I can't find any when I scan, can anyone help me please
Help scanning on dreambox 500c
you say you find no channels? what image are you using? do you carry out a bruteforce for uk scan?Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
what image are you using? Try reflashing with a new image, might sort the problem out. Always advise on saving the services file or the whole working image when you have the channels setup the way you want so if something goes wrong you can reflash your working image or your services file back.Comment
If it is not a physical cabling fault, it sounds like you need to update your cables.xml file via FTP
"Automatic scans" contrary to myth are not algorithmic or exhaustive. They use the cables.xml file which contains a list of frequencies, symbol rates etc. to use when performing various "automatic scans" such as bruteforce.
If the frequencies and symbol rates do not cover the ones in your area you will detect no channels.
If you no longer have a subscription, there is always the chance they switched you off at the box at the end of your street.Last edited by alexh; 24 September, 2009, 13:25.Comment
Whatever!!
