dk1.1 audio
  • eurohawk
    • 33
    dk1.1 audio
    hi is there any way to switch off nar in audio permenently.
    i understand this can be done with some d box files, to save switching it on and off all the time using the audio button.
    im using dk 1.1 img.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    If you press the AUDIO button on a channel that has a narrator, select ENGLISH and it will turn the narration off.
    I think it remembers this selection for all other channels.
    • eurohawk
      • 33
      yes it does but when the box is switched off and on again you have to do them all again it dosent save the changes.
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        After you change the audio setting, press MENU > SHUTDOWN > REBOOT NOW. This should write the current config to a file on the box and it will use that config next time it boots.
        • alexh
          • 225
          Does this work??
          I was pretty sure which audio channel Enigma images choose and which audio channel contains voice-overs was non-deterministic (or buggy) or on a channel by channel basis?
          In the past I've been changing between two channels, both with voice overs, one has them enabled, the other does not.
          • eurohawk
            • 33
            hi worked a treat thanks a lot
            • degzy
              My remote has no audio button, its a small remote.
              Can i turn this off in the settings anywhere? Iv been looking but not found anything
