total re-map of channels in yorkshire
  • moonie
    • Aug 2009
    • 17
    Had no channels available this morning. hasd to to a re-scan, problem is the old channels are still present.
    How do I do a scan and remove all existing stored channels.
  • MetalKettle
    V.I.P.P.T. Member
    • 797
    delete all the channels in your bouquets which say "removed service" then goto all channels and add them back intothe bouquets.
    XBMC/KODI Developer
    • moonie
      • Aug 2009
      • 17
      I dont use the bouquets, my problem is that the 'all channels now have non working duplicates or x10 in some instances.
      • MetalKettle
        V.I.P.P.T. Member
        • 797
        Work down your all channels list. Any channels you dont want press menu button and delete service.
        XBMC/KODI Developer
        • moonie
          • Aug 2009
          • 17
          Thanks , is there a delete all services option ?
          • MetalKettle
            V.I.P.P.T. Member
            • 797
            You could delete the services file from var/tuxbox/config/enigma
            Then reboot and do a fresh scan.
            XBMC/KODI Developer
            • moonie
              • Aug 2009
              • 17
              cheers, I'll give it a go tonight.
              First time a total re-map has happened in the last two years. somethings a changing me thinks.....
