Only getting picture on freeview.
  • xxThe_Dice_manxx
    • Jun 2009
    • 8
    Greetings
    My DB500c box went haywire a few days ago so I reflashed it but now I can only get a picture on freeview channels.
    All other channels are a blank screen.
    I'm using the latest DK image and I presume the latest keys etc.
    Can anyone point me in the right direction on how to remedy this.
    Many thanks.
  • Broo
    • Aug 2009
    • 56
    What area are you in?
    • xxThe_Dice_manxx
      • Jun 2009
      • 8
      Belfast Northern Ireland.
      • Broo
        • Aug 2009
        • 56
        I am in Cork, and have noticed in the past few days a few channels are blank such as Setanta SP1 and Adult channels, I have been informed that nag/3 is on the way.
        • xxThe_Dice_manxx
          • Jun 2009
          • 8
          Thanks for replying.
          So what does this mean? has the cable provider done something to fup my box?
          And what is the general fix for such a fup?
          Also apart from physically cutting the cable is there any other way they can cut you off?
          Thanks again.
          • Broo
            • Aug 2009
            • 56
            What software did you download, I used Dreamup, if lookup the forum you might be able to download it.
            • xxThe_Dice_manxx
              • Jun 2009
              • 8
              Greetings
              I have reflashed with dk1.1 and using evo 2.2 not sure i'm using the latest keys etc.
              I'm still noly getting freeview channels and a black screen for all else.
              Can someone tell me what I'm doing wrong or give me a link to the latest files I need and an idea of which files go where would be much appreciated.
              Many thanks.
              • Bonesy
                • 655
                Originally posted by xxThe_Dice_manxx
                Greetings
                Many thanks.
                Have you put in the magic files yet via ftp (rom files) ?
                • xxThe_Dice_manxx
                  • Jun 2009
                  • 8
                  Thanks for the reply
                  I've put a load of files in the keys and scce folders but I'm not sure thier the latest or the right files in the right folders.
                  I need a link to the latest files with instruction on where exactly they go, I've looked around and searched google but I cannot find a download for all required files in one place nor a detailed instruction on where they go and what they do.
                  I can flash and gain ftp access to my box with ease its just a matter of these files I think.
                  • urban32
                    • Aug 2009
                    • 32
                    Funny you should be getting the black screen i am to i'm getting the same issue however i have added the keys and done a bruteforce uk and still no joy i hear that people have been using evocamd keys can ask do you put the usual keys over the evocamd keys please help many thanks
                    • Bonesy
                      • 655
                      Guys to read your box is sohwing the channels and sound etc on freeview channels it will not be the box which is causing the problem. It is certainly the lack or wrong files on the box.
                      If I where you I would get a backup image from someone else who has same unit in your area, just a backup image and flash that to the box...problem solved I bet.
                      • urban32
                        • Aug 2009
                        • 32
                        So if i was to do a backup of my image via dreamup will my image that i'm backing up effectively be downloaded from the box or will just be copied.
                        • xxThe_Dice_manxx
                          • Jun 2009
                          • 8
                          Greetings
                          Absolutely awesome
                          Cant thank you enough mate, all channels back in buisness
                          The Dreambox stuff rar had the works in it and after ftp'ing to my box and rebooting all channels came back
                          Thank you, thank you, thank you! to all that helped me, much appreciated.
                          Ciao.
                          • Bonesy
                            • 655
                            good to hear your sorted, now stick around and help others
