dm600c only fta channels
  • sukhvi
    • 42
    hi, im only able to get fta channels today,i havent changed any settings in dm600,everything was clearing till this morning,i have left the box on sky sports 1 and changed cams from evocamd 2.17 to mgcamd 1.20 but still only get fta channels,i hav a dm500c in another room but that is clearing all the channels,i am at a loss,any help would be appreciated,thanks
  • Neil
    • 194
    you could copy the keys from the 500 to the 600 and see if that works
    500c, 600c, 7025+cc, 7000s with a 1m steerable dish
    • sukhvi
      • 42
      i hav deleted the keys in dm600 and replaced them with the keys from dm500 but still only get fta channels
      • satman
        • 736
        make sure in your dm600 you have /usr/keys and /usr/scce which is same as your dm500 /var/keys and /var/scce
        boom!
        • sukhvi
          • 42
          im using the pli ite img there is both a keys and scce folder there,i have replaced these with the ones from my dm500 but still nothin,im gona do a factory reset and try and reinstall the ig again
          • Curious123
            • 2591
            Try using the Evocamd 2.13 to see if that clears your channels.
            • sherlock
              • 35
              Not sure but think you need to do a re flash and only change your keys in user/keys (
              Not var,(main folder) i also find the older cams work better evo 2.14 and mg 1.16also with config file 1.00
              with evo should clear no longer than 4mins (first install) and mg has taken 6-7 on first install.
              Hope this helps
              • sukhvi
                • 42
                did a fresh install and got it cleared on evocamd 2.13,thanks for the great input
                • Curious123
                  • 2591
                  Now that its cleared i would change to Evocamd 2.14.
                  • tomk
                    • 4
                    mine was the same now fixed thanks for the help
                    • loki6000
                      • 7
                      will the cables.xml file from dm600 work on the dm500 ?
                      • kagon
                        • 140
                        Yessir it will.
                        • napster
                          • 53
                          i tried this camd 2.14 and channels didnt clear when switching over just blank screen switched back to 2.13 and everything is fine.
                          cheers
                          napster
                          • Curious123
                            • 2591
                            The evocamd 2.13 is supposed to be quicker at picking up the keys than the other Evocams. Once you have picked up the new keys and cleared the channels I would not have expected it to go to blank screens when changing cams. I run Evocamd 2.14 on my dm600 and it runs fine, if you are not having any problems with your picture than I would leave it alone.
