What Image Works Best for Barbados MCTV
  • robert2179
    • 4
    My father is looking to retire to Barbados within weeks, we presently use digitalworldz image version 2.0 in the UK and it works a treat. If he were to take it to Barbados would it work equally as well? If so how do i scan it? bruteforce uk? please help. thanks
    You mean can you take a cable box to Barbados and watch uk programs on it ? The only way you can watch uk tv abroad is satellite or using a slingbox AFAIK
    <--Bulld0g added 3 Minutes and 53 Seconds later...-->
    Ahhhhhhh ignore that reply i should read the post properly
    • smirnoff_rules
      • 8603
      http://en.wikipedia.org/wiki/Multi-Choice_TV_(Barbados)
      god knows wot cams and keys they use out there m8
      • robert2179
        • 4
        Dreambox 500c flashed with digitalworldz version 2.0
        The keys that they use are in the satankeybundles. Surely if i ftp them to var/keys- keylist.txt with dreambox control center. Would i have to change the roms?. Would I have to manually scan it to pick up mctv cable or would it pick it up on an automatic scan? If so does anyone know the frequencies for Barbados mctv cable. And finally would evocamd update the keys the same way it does for virgin?
        • smirnoff_rules
          • 8603
          looks like sat is the way to go , have a look here m8 .. if anyones going to know its them m8 CBC - BarbadosForum.bb, TELLING-IT-LIKE-IT-IS
          • Curious123
            • 2591
            Satankeybundle is used on the satellite setup. Nothing to stop you from using the DW image but you will need to get the cables.xml file for barbados if they have cable otherwise your father will have to go for the satellite option.
            • satman
              • 736
              There is a cable service in Barbados because its one of the few other countries still using a nagra1 type encryption..
              Being totally honust, its not something i had time to look at myself, but I do know they use a different type of n1 keyroll tricks from us, but i do believe there is boxes work out there, and i firmly believe do-able on a linux box, You need a cam thats been tweaked probably at somepoint for there keyrolls and a keypack and as already mentioned a cables.xml although i think they use one of the standard 6900 or similar.. could be wrong there.. I will try and find out more info from you,,
              boom!
              • micromouse
                • 162
                22222222222222222222222222222222
                • satman
                  • 736
                  Originally posted by micromouse
                  barbados uses pk1 instead of pk2... till now none of the cam supports this...
                  Well only cam i know would support that isnt available for dreambox yet i'm afraid,,,,,,,
                  buy an iTgate
                  boom!
                  • micromouse
                    • 162
                    • robert2179
                      • 4
                      IT Gate
                      SATMAN, please can you explain to me what an ITGATE is and how do I go about to obtain one
                      Many thanks
                      • kagon
                        • 140
                        Many thanks
                        ITGATE is a Korean manufacturer of Dreambox-like (Linux based, PowerPC CPUs, etc.) set top boxes. You can have a look at the specifications here:
                        - It`s the Gate to your world - ITGATE -
                        Google "itgate" and I'm sure you'll find some UK resellers.
                        • micromouse
                          • 162
                          • robert2179
                            • 4
                            Cheapesst ITGATE model for Barbados
                            Can someone please help me, I have practically no knowledge about the ITGATE, I have dreambox 500c and a 7000s. Could someone tell me the cheapest model of ITGATE that I could purchase for Barbados. What Image to flash it with and what cam, from what I have read the h****cam would suit Barbados best. I am looking to purchase one and send it down to Barbabados to test it. Any help would be useful
                            • soursop
                              • Aug 2008
                              • 6
                              Maybe im your Angel, I am from Barbados,Just stumble across this site tonight the Dreambox500c is working here
                              N*l card will also work, however im told that there is an update file for the keys that also work without a card,any nagra 1 box should work
                              <--soursop added 2 Minutes and 46 Seconds later...-->
                              not sure i know how to navigate this tread, feel free to email me at [email protected]
