if somebody could please walk me through step by step on msn how to put roms and keys on a breambox 600 and get it up working again i will send them a reward, please pm me if you can help
chris.
thanks 4 getting back to me, i'm probably actually at a stage closer than u think, ive asked many people to help but they just post sticky threads and i cant do it, i had help last time on msn and i did it in a matter of 15 mins, ive got it plugged in a router, and i'm using xp, i'm at the stage of flashing the box, i'm going to flash it in about 10 mins with the pli image jade 3 and then i'll be ready to transfer the files over with flash fxp, the problem is is i dont know where the files go and i dont have the files, just gonna have a cig and i'll reply to your message, cheers in advance
chris.
chris.
u go to var>scce m8 and insert the extra files in there
first off before that mate......... i need to install the new menu so i can install evocam on my box, second i dont have the files, could you send them to me and also could i talk 2 you over msn, it would be alot easier, thanks
chris
ok mate no worreys, thanks for the rom files, do i put all the files in the ssce folder? i noticed that the are cam files do i put them in also?, i have evocamd (2.17b) installed so where do i go from here? have you got a cables.xml file also ?
dont i need a cables.xml file to do a bruteforce scan because when i secect scan sattellites and transponders all it comes up with is......... all (SR6900) and all (sr6875)
ok i have put my own cablkes.xml file in now, it says bruteforce for uk, its scanning now, after this dont you need to set the paramaters of the cam file or summet ?
