evocamds
  • zztop
    • Oct 2008
    • 24
    DM500 evocamds
    Where can I download different evocamds for the dm500c , I'd love the try them but i can't find any?
    searched: emu, emu 213, emu 2.17b with no results
  • smirnoff_rules
    • 8603
    l havent checked for some time now but the dk image was connected to a server and u could download them
    • zztop
      • Oct 2008
      • 24
      Where do I find the option to download?
      Am using image dk 1.1
      • red devil
        • Oct 2008
        • 690
        here is a couple for you to try
        • scuba
          • 198
          go to set up > kaos panel>addon manager
          • saj1985
            • 785
            btw i've got evocamd 2.12 on my dk v1.1 image,
            bit of noobish question but just wanted to ask whats the difference between these?
            dont they do the same job like?
            Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
            • zztop
              • Oct 2008
              • 24
              connect to internet then download them via addon manager
              excellent info here
              • ashali152
                • 37
                There are several different softcams that we can use; evocamd, mgcamd, newcamd & gbox. It doesn't really matter what one you use, they all do the same thing.Some emu won't work in certain areas or on certain providers
                • ashali152
                  • 37
                  If you keep trying different things the more you learn
                  • Devilfish
                    Administrator
                    • Feb 2008
                    • 7872
                    There is no difference for what it's used for in the UK.
                    The code that's used to decode N1 in evocamd_2.12 is the same code that is used in 2.17. The versions have progressed because other encryptions have been hacked and the code added to the existing binary. So later versions have loads of code for other encryption systems which is useless to folk using it on UK cable.
                    In fact, it goes against you to use later versions because they take up more space on your /var memory which could possibly make the box unstable.
                    • petermiller
                      • 10
                      how do i transfer the evocam onto my dm500c
                      • ashali152
                        • 37
                        try using filezilla to transfer any file to the box
                        • aseman
                          Hi guys, very new to this. Used to be on the satellite decyption several years ago for "educational purposes" but just got myself a Dm500. Was going to try to flash tomorrow. However, 5 minutes ago, my TV blew up (literally - loud bang from my plasma - had it for more than 8 years!)
