Just killed my box... Help!
  • J_L
    • 7
    Complete noob at all this I'm afraid... clearly got a bit big for my boots!
    I was trying to install a new image on my 500c as there were numerous channels that I wasn't receiving and I thought that would fix it - probably wrongly.
    I uploaded digital kaos 1.1 image to the tmp folder via Flash. All fine until I attempted the next step in the 'Getting the best from your 500 series' guide which was to use this command via telnet:
    cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
    Now I've just got a blank screen and can't reconnect to the box via Flash.
    Any assistance would be very much appreciated!!
  • mongo
    • 14
    change the ip address of your dreambox in network settings then reboot...should be able to get in now with your ftp clirnt now
    • Sicilian
      • 168
      You will have to use Dreamup with a null modem cable. (9pin serial).
      D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
      • J_L
        • 7
        Thanks for the pointers Gents... give these a go tonight
        • Bonesy
          • 655
          correct you need NULL modem cable and dreamup to recover this box.
          • toxic_shj
            • 46
            mate,
            follow this link and do it step by step you shall be fine.http://www.digital-kaos.co.uk/forums...ox-dreamup-33/
            and once you have completed the above
            follow this link to ftp your files to your dm.
            best of luck mate.
            • J_L
              • 7
              Slight issue - laptop doesn't appear to have a 9-pin com port.
              Bought the cable... thought it didn't fit because it was female to female connections and went back to buy an adaptor... turns out I'm trying to shove it into the vga port.
              Is there a work around at all?
              Thanks again gents, sorry to be dim.
              • andy4
                • 1125
                you will need a usb to rs232 converter cable m8
                USB to Serial 9-Pin Male Adaptor : USB Adaptors : Maplin
                WIGAN ATH the BLUE BRAZILIANS
                DWSTADIUM the theatre of SCREAMS
                <<<<--------if i've been helpful hit the Thanks button
                • J_L
                  • 7
                  Back to Maplin tomorrow!
                  Cheers mate, much appreciated
                  • J_L
                    • 7
                    Guys, thanks for all your help in here and various threads...
                    Now back up and running!
                    Much appreciated
