help still needs help
  • help
    • Aug 2009
    • 26
    hiya i am still having trouble i have done a factory reset i get all channels but when i got to sky sports 1 to start evocamd the info bar comes up at bottom but the screen stays blank
  • cunny
    • 4915
    reflash with working image, chances are the rom fixes are gone as its been reverted back to factory settings
    • Sicilian
      • 168
      What image do you have installed?
      Are you sure evocamd is installed?
      Have you ftp'ed the magic files to /var/keys/ and /var/scce/?
      D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
      • help
        • Aug 2009
        • 26
        yeah i think i have done all that soz really new to this i thought i was clever getting it going in the first place i have put dreambox stuff in keys folder and bin files in scce but to be honest dont know if i'v done it right maybe not would it be worth doing thing with null cable again
        • Sicilian
          • 168
          What image are you using?
          Chack that you enabled evocamd in blue button menu.
          Did you chmod 755 both the keys & scce files?
          • mr.mojorisin
            • 247
            if you've done a factory reset then that will have taken all the "magic" off your box therefore only FTA channels available.
            • help
              • Aug 2009
              • 26
              dont really know what that means tried seeing if evocamd was enabled but dint know how to check
              • help
                • Aug 2009
                • 26
                so i have to do the thing with null cable again
                • Swiftie
                  • 141
                  Well some people on here have tried to trouble shoot onto what stage you are at. As it looks you probably just missing the magic files.
                  But hey.
                  Just reflash the DK image and start again i suppose. At least that way then you can follow the instructions available here.
                  E Pluribus Unum
                  From the one to whom much has been entrusted, even more will be demanded!
                  If you have received help from this post, press the "THANKS" button to show your appreciation.
