Help! Almost there but still no channels!
  • dirtybreaks
    • Sep 2009
    • 18
    Hi
    I've just read through the total-spoonfed guide, everything seems to have been done correctly. At the end it says 'go to Sky Sports 1' - I can't find any channels on the dreambox at all!
    I checked the folders on FlashXTP to see if the keys were there and the files in the scee folder and they are all present.
    I checked on the dreambox itself and can see the files in the scee folder but not in the keys folder - is that a problem?
    Also, I noticed that when using Flash, there was no keys or scee folder - I had to make my own folder and then drag the files into them. I don't know if that is an issue.
    I'm almost there after a very long wait - can anybody help me over the finish line please?!
  • jfish
    • 799
    Originally posted by dirtybreaks
    Hi
    you need to scan for channels initally, use Bruteforce
    • dirtybreaks
      • Sep 2009
      • 18
      Thanks for the reply jfish but I have no idea what brute force is. Is it already on the dreambox or is it something I have to download? If so, how do I get it onto the box?
      • Scarface
        • 92
        If you have a UK image flashed goto Set up > Service Search > automatic Transponder search, and scroll through untill you find Brute force, it will then lock, and you will then be able to "start Search"
        • dirtybreaks
          • Sep 2009
          • 18
          Thanks, tried that but there are only 2 options to scan:
          All (SR6900) and All (SR6875)
          Tried scanning both but no channels found. No mention of brute force.
          • dirtybreaks
            • Sep 2009
            • 18
            Ok guys, I think I have made a very silly error and not uploaded an image! Sorry about that, will retrace my steps and rectify this and hopefully all will be ok.............
            P.S. Can I just upload the image now or will I have to clear everything and start over again?
            • dirtybreaks
              • Sep 2009
              • 18
              Actually, I was right first time, I did do everything correctly! I wasn't sure because it has been a couple of weeks between flashing the image and putting in the keys (long story!) but I did flash an image - Digital Kaos v1.1.
              Just done the whole process gain in about 15 mins and still no channels, no brute force etc but everything else seemed to go without a hitch.
              Could the problem be with the image? Is there something I should be seeing when I switch on the box? It just goes blank until I press the menu key - is that normal?
              • bugaloo41
                • 1598
                how are you flashing the image with telnet or dreamup? are you definitely getting an incoming feed. make sure the cable is fitted without any splitters straight into the box.
                • dirtybreaks
                  • Sep 2009
                  • 18
                  I'm using dreamup. The null modem cable is attached straight from PC to the box.
                  • Swiftie
                    • 141
                    The cable in question was the actual CABLE Feed rather than the null modem cable. Anyways, as long as you're confident that your image has been flashed correctly and you have your key and rom files in the right place. Can you have a look to see if you have the cables.xml in /var/etc if its a DM500C that you have.
                    E Pluribus Unum
                    From the one to whom much has been entrusted, even more will be demanded!
                    If you have received help from this post, press the "THANKS" button to show your appreciation.
                    • dirtybreaks
                      • Sep 2009
                      • 18
                      Ah, you mean the virgin TV cable feed? I had no idea that this needed to be connected during the flash!
                      In the user guide on here, it says to disconnect all wires from the box and then attach the null modem cable - no mention of connecting up to the cable TV.
                      Will try again with cable connected, gonna feel stupid if that was the problem but if you read through the spoon-feed guide, doesn't say anything about having it connected..........
                      • bugaloo41
                        • 1598
                        db the feed doesnt have to be connected when you are flashing i just meant that when you are scanning make sure you are running the cable feed straight into your box.
                        • dirtybreaks
                          • Sep 2009
                          • 18
                          Ok, well I tried to flash with the cable connected and it worked this time! Digital Kaos is now on screen, all channels are downloaded with bruteforce..............but non of them appear apart from the FTA channels! All are blank, even after starting evocam. Any suggestions?
                          • bugaloo41
                            • 1598
                            they shouldnt all be blank you should be getting free to air channels. to get the scrambled channels you need to add the keys and rom files. i assume you have them if so copy the contents of the folders into the same folders on your box. reboot the box go to ss1 and let it update.
                            what area are you in?
                            • dirtybreaks
                              • Sep 2009
                              • 18
                              Yes, I'm getting the FTA channels but have input all the keys into scce and keys folders, rebooted but still blank. I'm in Nottingham 2.
                              On the PC it shows on Flash XTP all the keys and nag files successfully transfered but on the TV, I can only see the nag files - is this correct?
