How to upload cables.xml onto Commando 15.1b for DM500C
  • speedstar205
    • Sep 2012
    • 6
    Recently i upgrade my DM500C to Commando 15.1e, setup location to UK but there is no program that i can view
    i believe i have to upload the cable.xml list into the box then i can watch those channels.
    any pro can shed some light on these.
  • plasterer
    • 1631
    Have you set up your location to do a vm scan............Paul
    PAUL
    • 12345guy12345
      • Nov 2012
      • 162
      Is there any help on this subject? Im strugling to get a full scan on this image too.it wont accept my netid frequency and symbol rate it just says no bouquets found.It will only scan areas miles away after i set my location and run auto bouquets
      Sent from my SM-G900F using Tapatalk
      • speedstar205
        • Sep 2012
        • 6
        i mean it is for hub channel
        • satsmo
          • 6397
          Why would you set it for UK then? You need a cable.xml for your area which I can only presume may be available?
