Backup image
  • MILLWALLFC
    • 173
    Backup image
    Now i have my image working how do i back this up for the 600pvr box and how long will it take.
  • smirnoff_rules
    • 8603
    just backup in the menu m8 and it saves to the harddrive .. u might have to download an addon im not sure wot image u have .. its on mine
    • MILLWALLFC
      • 173
      using this image. pli-iolite-dm600pvr-20071230-4014.nfi
      I went to plugins and downloads but nothing there.
      Went to backup menu it says download latest menu bar which i did but still nothing shows.
      • smirnoff_rules
        • 8603
        have u rebooted m8 ?
        • MILLWALLFC
          • 173
          Yes have rebooted e.g. pulling out power cable but still no joy.
          • Curious123
            • 2591
            @smirnoff are you thinking of the backup and restore plugin if so that won't be available on the pli image as it was one of mr dudes special plugin. Copy the one below to var/tmp and then install manually.
            • satman
              • 736
              Mate, the 600 backup plugin isnt mr dudes work, although is in his image,,,,
              boom!
              • MILLWALLFC
                • 173
                Thank you going to try this one.
                plugins.tar.gz
                Think you need it to end with the GZ to do a manual install.
                <--MILLWALLFC added 20 Minutes and 51 Seconds later...-->
                ok i tried this one "plugins.tar.gz" and rebooted box but still nothing. How do i install teh other file manaully if it does not end with .gz
                • Curious123
                  • 2591
                  @satman you maybe right m8 but I only came across the plugin for the first time on his noob image as I was one of his beta testers so that was why I gave mr dude the credit for the plugin.
                  You need to extract the file for the zip file and than ftp to the var/tmp directory on your dreambox and than press the Blue button and select manual install. You should hopeful;ly see plugin.tar.gz file and you can than select to install maunally.
                  • MILLWALLFC
                    • 173
                    nope, tried extracting the other file but as its not a tz or gz file it wont allow me to do a manual install after reboot it does not see it to let me install.
                    • Curious123
                      • 2591
                      The var/tmp gets deleted after each reboot so you won't see it in the tmp again. You are going to have to ftp the files to the relevant directories and than do a chmod 755.
                      • MILLWALLFC
                        • 173
                        What is a chmod 755 and how do you do it, sorry if the naswer is simple.
                        I have extracted the following files to the tmp directory.
                        dm7020-dm600pvr - FOLDER
                        dm7025 - FOLDER
                        build-nfi-image.sh
                        secondstage.bin
                        • satman
                          • 736
                          dm7025 - FOLDER
                          build-nfi-image.sh
                          secondstage.bin
                          Hes talking about his .tar.gz file mate,, probably easier using that if your not comfortable with this,...
                          boom!
                          • Curious123
                            • 2591
                            I am not familiar with the files you extracted. chmod sets the permissions on the files normally done by right clicking on the files in your ftp program.
                            • MILLWALLFC
                              • 173
                              ok i did your file "plugins.tar.gz" and put in tmp directory, i did manual install it said sucessful but then nothing still appeared in the backup after ?
                              <--MILLWALLFC added 0 Minutes and 30 Seconds later...-->
                              oh just seen this
                              ftp the file to the tmp dir, telnet into box and issue these commands:
                              cd /
                              tar -xvzf /tmp/plugins.tar.gz
                              I give it ago.
