Do I have to keep cable connected during ftp?
  • rmmkkenny
    • 5
    DM500 Do I have to keep cable connected during ftp?
    Hi guys, i've read a few guides and watched this video here [ame=http://www.youtube.com/watch?v=B7IOS9Yd4oI]YouTube - DREAMBOX 500C TUTORIAL[/ame] which was helpful but it says when doing ftp with my dreambox 500c i need to connect the scart lead, power unit, cable feed and network cable all at once. I tried doing this with with the 'crossover cable' method but had no luck. Would i get away with not connecting the cable feed during ftp as the i'm going to try and connect straight to the router but its in a different room...
    thanks in advance for helping this noob!
  • rmmkkenny
    • 5
    also i should add when I just plugged the dreambox in and did a scan i didnt even get fta channels. should i worry about that?
    • whitey83
      • 24
      No cable feed needed during ftp.
      As for no fta channels. You'd be better listing what you've done already to set up so someone can point out where you've gone wrong / what's wrong with it.
      • rmmkkenny
        • 5
        just plugged the box in and did an automatic scan, came back with nothing every time I tried. The dreambox is running on enigma.
        • whitey83
          • 24
          So what are you ftping then?
          • mini
            • 602
            Is there a cable signal coming through to your home. Also have you tried doing a scan using set your location, its found in the sub-menu. To ftp to your box using a crossover cable is simple mate. You just set your pc / laptop I.P. one below that of the box (ie: pc/laptop 192.168.0.22 - dreambox 192.168.0.23)
            • rmmkkenny
              • 5
              managed to get them going by just going through router..(long story!)
              there's a live virgin cable feed coming into the house, i'm gonna flash the machine and start from scratch i think...
              • Donnie Darko
                • 442
                Forget the base image supplied with the box,download 1 from in here and use that.
                Checkout the RED stickies massive amount of info and effort been put into them.
                • rmmkkenny
                  • 5
                  i just tried the pli jade3-enigma 1 image. used telnet and had no problems at all, dreambox is working fine but when ever I do an automatic search I have 2 transponders to choose between (SR6875 and SR6900) and after a scan both bring back the message 'All known transponders have been tried, but no lock was possible. Verify antenna-/cable-setup or try another satellite/network.
                  I have an old telewest box in the living room that gets the fta channels as the tv contract expired a long time ago but I still get the internet/phone from virgin so feed is alright. Any suggestions? Would it be worth trying another image, the dk image perhaps? or just keep on scanning in the hope I get a 'lock' and 'sync' eventually...?
                  • Wale04
                    • 44
                    Please could anyone give a lead on image file for Drea*b*x C for dublin area.
                    • andiewill
                      • Aug 2008
                      • 490
                      Try one of these in downloads here which are the uk image's which will have scan options UK6952 or 6887, and a brute force scan for your area, as for the SR6875 and SR6900 i have no idea what area they are for but dont think they are for uk.....,
                      ITgate TGM220 (swapable tuner), Dreambox 800 pro, Dreambox 500c x 2, DBox, Popbox media player.
                      • Wale04
                        • 44
                        DM500- C
                        Thx for the lead i work on it; you are very gohttp://www.digital-kaos.co.uk/forums/images/smilies/captain.gifod.
