recording help
  • gav12345
    • 85
    recording help
    ok im a noob as i have never done this before!
    followed the guide to record to pc from dream using the new dk_v1 but it will not mount keep getting error
    info
    CIFS mount 192.168.1.10/Recordings /hdd/movie FAILED!
    any ideas followed the guide step by step
  • westkill
    • 2378
    hi m8 i havnt got a dm500
    but you could try /media/hdd
    this works on my dm600
    create a folder called recordings on your pc/hdd
    right click and share that folder
    • gav12345
      • 85
      yea i done that but still exactly the same never done recording before but i really need it lately
      • westkill
        • 2378
        if using cifs did you put username and password
        • Curious123
          • 2591
          I always find that the setup works better if I do it thorugh the web interface. Go to your browser and type in the ip address of your box and than select > Box control > Configuration > Mount manager and than type everything as you see below except the remote ip would be pc ip address.
          • gav12345
            • 85
            thanks forn your time on this
            still getting no joy im afraid
            but im willing to listen to anymore help
            • osborne82
              Dreambox Guru
              • 133
              what you trying to mount to ? pc, nas ? and how u conected to said item
              just sounds like your share folder on pc/nas hasnt been setup correctly.
              can you try mount either via webif or telnet ? (telnet would give us a few more hints as to why its failing )
              cheers
              osborne82
              • gav12345
                • 85
                cheers
                osborne82
                ethernet via lappy under Recordings folder under the d drive and set to sharing too
                telnet yes i can telnet the box
                is there a code i could type in that i can share the result here??
                that would be great thanx
                cheers
                • marsus
                  • Mar 2009
                  Thanks a lot for this post. I will try to mount my DM600 HDD to another DM600 which has no hdd inside.
