NGRAB, mounting harddrive,
  • MILLWALLFC
    • 173
    I have a couple of questions.
    I managed to get NGRAB working which was all good, but i thought with a Dreambox 600 you can record and watch another channel but i was unable to. Everytime i changed channels it stoped recording.
    Well anyway i thought i mount to a harddrive on my PC, i did this and it said sucessful, however i cannot seem to record to it, also what types of files can i play from my PC onto the dreambox i have tried serveral formats but it cannot seem to find anything to play.
    Anyone able to offer any advice.
  • Curious123
    • 2591
    You cannot record one channel and watch another channel unless it is on the same transponder.
    • MILLWALLFC
      • 173
      ok im using cable is that not all on one transponder ?
      e.g. i was recording SS1 and wanted to watch SS2 ?
      • smirnoff_rules
        • 8603
        when u record and check the channels u will see only a few there , there the only ones u can watch m8 .
        this is why l have 2 boxes and l use the upstairs box to record to and l can still watch on the downstairs box because there mounted to the same drive on the pc
        • MILLWALLFC
          • 173
          ok i dont seem to get an option i do the follwoing.
          ON TV Channel press Yellow key and then i click start NGRAB.
          Or i can push red and record by EPG.
          However how do i know what other channels can I watch.
          Do i go to providers and select the one thats default e.g. Nopig_140 for S*y Sports 1. I take it if theres nothign else in there i cannot watch it.
          If i have recordings on PC how do i play them on Dreambox and plus since ive mounted a harddrive how do i record to there. I can only seem to record by Ngrab.
          • smirnoff_rules
            • 8603
            when u go to your channel menu u will only see the channels on that transponder u can want
            • MILLWALLFC
              • 173
              Oh well mines different then, when i go in it shows all channels then when i click on it says "A recording is currently in progress, this stopes the recording" Yes and No option. That's when i try to change channel.
              It's a Dreambox 600 maybe they are all different.
              • smirnoff_rules
                • 8603
                l have a 600 . u can watch another channel when its recording .. l do only pick wot l want to record from the multi epg tho
                • MILLWALLFC
                  • 173
                  ok well i do this. I am in TV mode and i press RED to get into EPG. I then select Yellow to record a channel and press green to apply. A red timer then comes up over channel however i can see all still in EPG view. I can change channel there and it just stops recording.
                  If i press exit and then down arrow i can still see all channels, maybe its becuase im using a different image, im using. pli-iolite-dm600pvr-20071230-4014.nfi
                  • smirnoff_rules
                    • 8603
                    strange that mines a pli image . when l open the Bouquets say in the fta one theres only 4 or 5 channels and not the 20 that was there before ? ..
                    will have a play tomorrow . but l have a harddrive in mine but done use it as l find recording to my mounted drive on the pc is better
                    • MILLWALLFC
                      • 173
                      How do you record to mounted one, i cannot seem to do it. I can only select Ngrab nothing else is there ?
                      • smirnoff_rules
                        • 8603
                        mine has record dvr and then i can pause/record and watch the channels on that transponder m8
                        • MILLWALLFC
                          • 173
                          i dont have an internal harddrive in the system at the moment.
                          • westkill
                            • 2378
                            this might help if im on the right track
                            this is my setup for recording direct to a mount using dm600
                            a shared folder on your pc called recordings
                            add username and password
                            press video then the radio button to record
                            or the record button on the web interface
                            • MILLWALLFC
                              • 173
                              Hi cheers.
                              I tried to mount one with your settings but i twould not let me, pics attached.
                              On the Options screen prompt i do not get the same option, only read and write. Also as i mounted one before when i mount this i receive this error.
                              Any ideas what to do next ?
