Dreambox arrived dead from DVBseller?
Well replacement finally arrived this week got it all setup working used for about an hour.
Next day switched on comes up on display " Dream Multimedia error!" Tried using dreamup which worked fine the day before and bar goes to 100% and says waiting for acknowledgement and nothing so cannot flash anything to it so its knackered again so pissed off!!!Comment
That error is same one I have, which I got by stupidly updating the image to the latest one (timebomb not removed)Well replacement finally arrived this week got it all setup working used for about an hour.
So it is not hardware problem, its all software and to be honest my fault
Now cant connect via dramup, wont go into flash mode by holding down the botton.
So order jtag connection other day, which should arrvie today to try and recover it. If works great, if not, returned to dvbseller for replacment
Got to love dreamboxs, what other electrical equipment do you know which you can mess so much with the software of it and it doesnt invalidate the warranty on the hardware?
Are you sure that is the problem. I flashed your backup image and was coming up no ca error tried it multiple times so flashed bootloader 72 r1 and it then booted and worked fine. Switched on the next day and get this error. Have I done something wrong to cause same fault?That error is same one I have, which I got by stupidly updating the image to the latest one (timebomb not removed)
Yep it is, I got your pm thankyouAre you sure that is the problem. I flashed your backup image and was coming up no ca error tried it multiple times so flashed bootloader 72 r1 and it then booted and worked fine. Switched on the next day and get this error. Have I done something wrong to cause same fault?
My box is now working again so will post and give you repSetup: 2x Dreambox 800HD | 3x Dm500S on Motorised dish Setup
