backup image
  • pingg20
    • 66
    backup image
    hi can anyone tell me how to save a backup image thats working fine on d/b 500c so i can flash onto other box in the future using dreamup
  • Dreamer
    • 2020
    I think You can user Telnet or dreamup
    I have not done this myself but there is some info in the stickies here.
    All receivers supported, 500, 500+, 600-PVR, 7025, 800 and 8000. Get the most out of your Dreambox!
    Hi, I am totally new to the whole dreambox world and have a question about images. I just got a 500c and set it up correctly at home so no issue there. I think I am running an enigma image (ditigalworldz). My question is why would any body change their image to Kaos V1 if they had no issue with there old image. What dose Kaos
    Quote from this post by Satman
    "backup with dreamup and a null modem cable and you will get a good backup of the 500, just make sure when flashing/restoring a backup image when you flash with dreamup to select NO to flash erase after flash..."
    __________________
    You could just put a new image on from scratch like the DKv1 image
    Well it's been a long time coming but it's eventually here - Digital Kaos v1 image for all versions of DM500, cable satellite and terrestrial. Please read this post in full before asking any questions. All questions with answers in this post will be referred here. A few details about the image! Yellow - Kaos Panel
    The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
    • challah
      • 242
      open dreamup connect to the box select backup choose a folder and your off
      • Donnie Darko
        • 442
        Or use flash wizard pro.
        Checkout the RED stickies massive amount of info and effort been put into them.
        • 6666a
          • Feb 2008
          • 9
          backup not available to load
          hi, i made a backup by Dreamup saved it ,when i try to load backup -by clicking Flash ,its not there for selection to chose from the folder where its saved.why?its not saved like Image file..how i can change that saved file to image file.
