Dead Dreambox - Flsh Erase?? :(
  • mpcrudeboy
    • 12
    #16
    I have the same problem & have a null cable no usb, did you fix this?
    • rieko
      Having the same problem.
      • mark015
        • 254
        #18
        heres the flash erase file for the dreambox in rar file
        • alarmeng
          • 78
          #19
          Hi fella
          I use a bit of software called colasoft mac scanner. its free and scans your network.
          Good kit fella try it.
          Gaz
          • hkfun2k7
            • Mar 2010
            need eraser.rar or easer.zip
            do i load it with dreamup?and coms cable?
            • masterficx
              • Mar 2010
              can someone help with an explanation of how this works
              • conceptBox
                Does a usb to serial is enought, or do I need a null modem cable?
                • westkill
                  • 2378
                  #23
                  still need the null modem cable to attach to the usb to serial lead
                  • EAMO 2
                    • 1201
                    #24
                    Would be easier if you use PC with RS232-port & null-modem
                    cable only. Saves a lot of heartache
                    • fvieira
                      flash erase
                      Where can i get the flasherase zip file
                      • EAMO 2
                        • 1201
                        #26
                        Just in case you did not do anything with that box & have time to kill.
                        Use old PC with rs232 port, null modem cable ONLY
                        Download Dream-up 1.3.2.1
                        Digital Kaos - Downloads - dreamup 1.3.2.1
                        Follow Dream-up prompts;
                        Don't power-up box until prompted to
                        Say no to FLASH-ERASE when asked.
                        If no success try diff Dream-up version
                        • ghat
                          • Jun 2012
                          I have a dm600c that I'm trying to fix.
                          It starts but hangs on the PLi Jade image at startup.
                          It won't take commands from the remote control.
                          Both green and red lights are on and after a while it reboots.
                          Can't connect to it via null modem cable.
                          DreamUp says "Connected, now power up box". When I do, nothing happens. It never recognizes the box.
                          The box doesn't seem to be getting an IP on my router.
                          Is there any hope of getting it running again?
                          Thanks in advance.
                          EDIT: Managed to flash it using an older computer with a com serial port. (Used USB converter on laptop before).
                          Not sure what the issue with the remote control was, but it's working again.
