fxp services + bouquets xml onto dreambox500c
  • pingg20
    • 66
    hi folks where do i transfer my saved services and bouquets xml files to useing fxp
    they are for ntl glasgow area barlanark im useing d.w 2.o image at the mo and after transfer would i have to scan for channels and lastly would they come sorted in a proper order in there bouquets i.e bbci bbc2 stv foure five ect thanks in advance.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    If you have a services and bouquets file with a .xml extension then they won't work on a dreambox running DW v2 image.
    Your best bet is to bite the bullet, sit own with the remote and sort them out yourself, it will take you about 30 mins and that'll be you. You could spend days looking for files that are already set up and you can have them done in under an hour doing them yourself.
    There's a guide here...
    Digital Kaos - Downloads - How To Setup Bouquets on Gemini and Enigma Images
    • bob114
      • 192
      hi
      I have changed dbox sevices to dreambox using bouquetter on other dreambox images
      my question is their a program to convert services either from dbox or dreambox to
      service.tar.gz files (needed for dk v1 or dw images)
      or is it just a case of doing what devilfish says (will bouquet wizard work )
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        Telnet to your dreambox and paste this command to generate the services.tar.gz file.
        tar czvf /tmp/services.tar.gz /var/tuxbox/config/enigma/services  /var/tuxbox/config/enigma/bouquets /var/tuxbox/config/enigma/cable/*
        • bob114
          • 192
          hi
          again thanks
          I will have a read on how to "Telnet to your dreambox"
          • bob114
            • 192
            hi
            I managed to use telnet to make services tar.gz file (shown as a rar file)
            from dreambox image Iam using
            flashed dkv1 to dreambox all channels (no order)
            ftp services.tar.gz file to tmp folder
            yellow button /user features/--ServicesRestore
            screen asking to put services.tar.gz to tmp (no file showing on screen in tmp)
            any help please
