dreambox 500c clone
  • joyscroft
    • 4
    dreambox 500c clone
    can anyone help i am trying to find the ip address for my box if i go expert setup-comms setup i get 10.0.0.97 but i cannot get any connection on ftp on this number any help would be appreciated
  • thospot
    • 18
    Originally posted by joyscroft
    whats your pc ip ? 1f your pc ip is something like 192.168.1.44 then change you box ip to 192.168.1.42 the first 3 blocks of numbers must corasponce
    • bobbybritt
      • Oct 2008
      • 54
      hi first you must uncheck dhcp.
      • thospot
        • 18
        forgot about that
        • joyscroft
          • 4
          many thanks bobbybrit have now got a ip192.168.0.24 but it still will not connect with flash fxp. if this goes on it might be the nearest bin
          • Bonesy
            • 655
            If your trying to flash the unit, just use Dreamup and null modem cable.
            Setup: 2x Dreambox 800HD | 3x Dm500S on Motorised dish Setup
            • bobbybritt
              • Oct 2008
              • 54
              hi if your db is set at 192.168.0.24 then pc at 192.168.0.22 default gateway set to 192.168.0.2.hope thi helps
              • joyscroft
                • 4
                HI,bonesy,
                thanks for your help i have now loaded a dw image that a member sent me with null modem cable, it was supposed to have keys on already but i now have all free channels epg but noyhing else can i get keys and load them without losing what i already have as its taken me two days to get this far good job i am retired.
                many thanks
                • bobbybritt
                  • Oct 2008
                  • 54
                  hi just download the magic files put them in var/keys and scce in var/scce chmod to 755 go to ssp1 and reboot box.hope this helps
