DM800C/S - Help Please
  • king03j
    • 18
    Hi guys, apologies in advance if this is a dumb question but i need help establishing what i'm doing wrong - I think the answer is that i have a DM800S and not a DM800C as ordered but i'd appreciate confirmation from the experts if you don't mind.
    So far I have installed the modded nabilo sat image, added MGCAM 1.30C, FTP the keys & SCCE, changed the file permissions, rebooted and all has gone smoothly to this point.
    The stage i'm at now is Tuner Config - there is nowhere to enable cable or select 6952 for ex t/pest?
    The tuner choice is - Tuner A: Alps BSBE2 (DVB-S2)
    Do i have a sat box here or am i missing something please, any help would be greatly appreciated.
    Kind regards
    King03j
  • caveman_nige
    • Feb 2008
    • 4920
    yes it is a sat tuner and will not work for cable as you say
    • Bonesy
      • 655
      yep diffo sat tuner in your unit...wont work with cable unless you change the tuner.
      • karlpowell
        • 189
        the tuners are plug and play , just a few screws , remove the back panal and pull the tuner out .. you will need to buy a cable tuner DVBC . If i was you I would stick with the satellite one .
        Karl
        • dctyper
          • 2539
          a new tuner will cost around ?30 mate
