Not sure how to get the cams onto a dm800C..cant seem to find where to download them, probably because its not a DK image and not connected to the server...so where do i download them and where do i install them to...thanks.
Cams for DM800
Ahh...found it...this image has green panel not blue, its all there anyway.....what are the common cams to use or indeed i NEED, also does anyone know if the picons work on these images and can anyone confirm the EPG works on black hole image for uk cableLast edited by loady; 14 November, 2009, 08:40.Comment
My reply in another thread about this.
"Hi guys.
I have had my DM800 HD since they first came out, I have had every image possible on it, and messed around for hours and hours, this is what I have found.
All images will clear with Mgcamd (all versions) but will freeze, sometimes it will clear and run fine for weeks/months but other times will freeze repeatedly about every half-hour or more.
Blackhole 0.7 will clear and auto-update and NOT freeze with Evocamd but ALL other versionsof Blackhole and all other images are Free-to-view only with Evocamd.
So, for me its Blackhole0.7 and Evocamd, its the only image that will run Evocamd and Mgcamd is useless due to the freezing! Don't know why or what is different about v0.7 but it works for me. I try all the new releases every now and then and all new versions of Blackhole (up to 0.12) but nothing else has so far worked.
Don't know if its important, but I always update 0.7 with the latest seccond-stage-loader I can find, at the moment that's 75. Hope this helps and if anyone has any sugestions for getting later versions of Blackhole working I will gladly test them for you."Comment
