editing fonts in esml files
  • bob114
    • 192
    hi
    I have edited the esml file on enigma images (dbox) to make some fonts larger
    editied esml files on dreambox images but when tried to ftp edited files back to dreambox the files would not transfer
    (this happened on more than one dreambox image)
    Iam I doing somthing wrong
    thanks for any help
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    The esml file will originally be in the /share folder which is read-only.
    If you want to edit a skin and put it back on the box, change the name of the file and also change the name inside the .info file too.
    Then upload the new files to /var/tuxbox/config/enigma/skins. You will also need the pictures folder from the /share folder to put in /var/tuxbox/config/enigma/pictures. All fonts are normally in /share/fonts but if you have added new fonts to the .esml file then you'll need to add them in /var/tuxbox/config/enigma/fonts.
    Hope that reads ok .
    • bob114
      • 192
      hi
      thanks again Devilfish
      "The esml file will originally be in the /share folder which is read-only"
      will be the reason i carn't change fonts only done this once on a dbox
      (running before I can walk) but I have learn't something new
