quick question
  • firestorm
    • 1550
    quick question
    hi i have just flashed my 500c with digitaworldz v.2 all channels are there i press the blue button go to addons then download addons then it says "server not found" which is strange as i can access the box by dcc see all files var ect so i know the cable is ok the rooter is open as i use a 7020si which as the same ports open(i am using the same ethernet cable just unplugging from one to another as i set up).but all i can get is free channels any ideas would be welcome as it many years since i had a 500s.just to add to this i have now got the premium channels cleared by ftp the keys across but still cant get acsess to the server
  • davemac82
    • 279
    try using the dw2.1 image m8 all the files you need are on that, also the digital wprldz server cannot be found because it does not exist anymore they shut it down just after the last hit., if ya need anymore info or help give me a shout
    • firestorm
      • 1550
      thanks m8 that cleared that up for me i will use 2.1 infuture
      • javaoverride
        • 71
        most of the downloads that where on the server can be found floating around the net mate was there anything that you wanted or did you just want to browse
        • firestorm
          • 1550
          i was just playing with the box and was looking to try diffrent cams and could not understand why i could not get the server not having a 500c before (only starview)but thanks to davemac82 answer i now no why
