PLi? Jade - for the Dreambox
  • satman
    • 736
    DM500 PLi? Jade - for the Dreambox
    PLi? Jade - for the Dreambox DM500
    [PLi? Enigma1] PLi? Jade Images Suite 20080713 Rev.5335
    In memorial to our Danish friend Gaj1, rest in peace Johnny!
    A new Enigma1 PLi? Dreambox release is available for download.
    The Original Enigma1 PLi? Jade suite contains the following images:
    PLi?-Jade-DM500
    PLi?-Jade-DM500-Old-Framebuffer
    PLi?-Jade-DM500Plus
    PLi?-Jade-DM56x0
    PLi?-Jade-DM600
    PLi?-Jade-DM7000
    PLi?-Jade-DM7020
    See below for what's New, Fixed & Features since the initial PLi? Iolite release
    Or have a look at the MovieClip prestation on PLi-images.org... or at YouTube...
    We think it is important to have a PLi? image twice a year available in summer and winter.
    Therefore, we have decided to make a steady Release Candidate public.
    As it is a steady Release Candidate, you might run into some unknown bugs.
    Please report any issues or bugs on our forum, so we can fix it before the final release of Jade.
    Highlights:
    - EPG Search added
    - Complete redesigned backup/restore menu
    - Fully programmable Blue and Yellow buttons to any menu or Plugin/PPanel
    - Complete redesigned network mount screen
    - New movieplayer plugin as a full and better replacement for the VLCF plugin
    - Permanent timeshift integrated in recording and playing menu
    - Global worldwide Picon Sets added per Satellite / Provider
    Enigma1:
    - CVS Repository June 29th 2008
    - PLi? Repository July 18th 2008
    - RC repeat fix
    - Build non-LCD boxes without DISABLE_LCD, so binary plugins will work
    - Don't shut the box down on fatal Enigma errors
    - Enabled TimeShift for DM600
    - 2nd stage bootloader: Auto reboot after flashing nfi (DM500+, DM600, DM7020)
    - Improved BER
    - Auto Adjust AGCR1 to improve BER after tuning (yet only available via the registry)
    - Disabled fast zapping for DM500 and DM56x0
    - Mount network mounts as first step so EPG can be on a network mount
    Plugins:
    - Build Streamts with large file support
    - Install movieplayer by default on all boxes
    General, openembedded images:
    - Several ipkg improvements, speedups and bugfixes
    - Ushare and djmount (uPnP mediaserver and client) added
    Drivers:
    - Added keyspan usb2serial driver (DM7020)
    Skins:
    - ePicon widget added, used by skin and multiepg
    * (uses serviceref piconnames, auto resizes picons to specified dimensions)
    - X-Line skin updated
    SQLite:
    - Updated to version 5.3.9
    Network Mounts Fixes:
    - If a network mount is edited in the web interface, it's automatically unmounted
    - Use udhcpc config/deconfig script
    * This solves the problem samba fails to start in case the DHCP assigns another hostname
    Network Mounts Features:
    - DM7000 allows NFS V3 mounts too
    - Support for NAS devices which cannot handle cifs Linux extensions
    - /VAR can be easily moved to a network mount
    Web Interface Fixes:
    - Several in web interface/movie source
    - Several in web interface/remote control
    - Several in web interface EPG
    - PDA webif improvements by Jonc
    - Updated working forum links in webif, now containing links to the PLi? wiki
    Miscellaneous Fixes:
    - Several TuxTXT bugs
    - More support for the DMM keyboard at several places
    - Better remote control support for fx2 games
    - Several fixes for Tetris
    - Fixed the unresolved symbols issue for various SoftCams
    - Sample PPanel can be uninstalled now
    - LCD output for PPanels fixed
    - Capacity in harddisk menu fixed
    - RSS configuration path
    - Improved harddisk detection
    - Satellite setup fixes for more then 80 active satellites
    - Recording and playing fixes if a network mount is unmounted
    - For writing EPG data to a network mount
    - Disable PIG on DM500+
    - No longer use (part of) the recordingdescription for repeating events
    * Just use the current date as additional description
    * Extra info will be in the EIT file anyway
    Miscellaneous Features:
    - Default zapstream for streaming to a PC
    - Removed: "Show installed PPanels"
    * All PPanels are visible in the plugin screen
    - Support for dropbear in CDK images (DM500/DM56x0/DM7000)
    - Forward/backward skipping using the remote control number buttons
    - "Blue button" completely integrated with Enigma Setup
    * (Removed: PLiKey ppanel)
    - EPG Search added
    - Added <menu> for PPanel to call any Menu from a PPanel
    - Support for opening PPanels using an URL
    - Movie directory automatically created and automatic fallback to internal harddisk if anything fails
    - Swap menu added for oe boxes
    - Ipkg support in PPanel
    - Added DISH LNB setting support in Satellite configuration wizard (at first boot)
    OSD Fixes:
    - Date in OSD fixes
    - Cosmetic changes in the Timer Menu
    OSD Features:
    - OSD is aligned according to OSD offsets
    DM500:
    - CCcam Softcam updated to 2.09
    Further:
    - Thanks to ims for EPG Search, Movieplayer Plugin and several fixes
    - Some EPG webif changes by Alphons (we've added it to the CVS repository)
    - EPG Search based on Sourceforge Merlin project
    Thanks to the PLi testers for several fixes and features
    Support:
    - Online update support (IPKG feed) for OpenEmbedded boxes (DM500Plus/DM600/DM7020)
    - Global satellites.xml updated July 5th 2008
    See our brandnew PLi? Jade Wiki...
    Many low level changes fixes and other updates...
    Download here...
    Digital Kaos - Downloads - PLi Jade for DM500
    boom!
  • father ted
    • Feb 2008
    • 1389
    Originally posted by satman
    . ( sorry i am bit busy to spend all day uploading ), available in the usual places
    and that would be where?not the gents toilet outside the tube station is it
    • satman
      • 736
      pmsl,, no,, pli-images.org or rdi-dreambox
      boom!
      • HUPextreme
        • 30
        will this work with cable service?
        • zaf786
          • 327
          sat and cable
          • westkill
            • 2378
            has anyone tryed it yet is it as good as nabilosat
            • Curious123
              • 2591
              I have been Pli images for about a year and this new one works great on my DM600.
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                I've uploaded it here.
                Added evocamd and uk cables.xml for scanning.
                No keys or roms as usual.
                I wasn't that impressed with it...but then I didn't give it a chance .
                • zaf786
                  • 327
                  Hi thanks devilfish i tried to upload a 600 version was not able to do so the file is to big
                  • Devilfish
                    Administrator
                    • Feb 2008
                    • 7872
                    Yeh I would need to ftp it to the server manually due to upload limit.
                    If you want to send me it at [email protected] I'll upload it.
                    • aftermath
                      • 4345
                      if your trying to upload a sat version, its over 30mb so its too big.
                      if its a cable version , did you rar it up first ?
                      you could split the rar file into manageable sizes
                      • simonthedon
                        • 9
                        Updating ?
                        i just got this image on looks very nice,
                        anyone know ow i get it to update, i have added the rapidshare stuff
                        and restarted the cam a few times etc ?
                        thankyou
                        Simon
                        • Devilfish
                          Administrator
                          • Feb 2008
                          • 7872
                          Did you delete all the files in /var/keys before copying over the new key files? If so, that's why it's not working.
                          That version of evocamd needs a file called feynman.cfg and I think a newcamd-client.txt file. UK cable doesn't need these files but the emu won't work without them. Do a factory reset and copy over the scce and keys files again but leave the existing files there.
                          Or replace the evocamd file in /var/bin with a previous version.
                          • simonthedon
                            • 9
                            Thanks mate
                            Cheers devilfish,
                            done what u said, basically factory reset then copied me rapidshare files over but did not overwrite the softcam file inside or any others, tryed restarting cams, box a few times does nt seem to have picked up still.
                            When i look in cam section they are all on default except default softcam which is on ccam 2.0.9 , ( which is the only other choice) should i be seeing a evocam in there ?
                            Sorry if i sound thicker than i am
                            Simon
                            Simon
                            • aftermath
                              • 4345
                              @simon
                              i take it you on a cable box, and not sat ? as i am sure the CCcam 2.0.9 is for sat.
                              you can download and install cams from your remote control, blue button, then downloads.
                              thats if you are networked to your box, .
