DM500C
  • phimay
    • 11
    DM500C
    Hi just downloaded the images and flash to the box and it works well except there are lots of missing channel there and cannot scan transponder due to the password in setup.
    Any help to do things other way or have to get the pwd from the forums. Sorry if I about this anyway do appreciate if there is a solutions. Thank you very much
  • Bonesy
    • 655
    the dK image is not passworded. What image are you taking about?
    • dctyper
      • 2539
      password? only ones i can think of is user root password dreambox
      • phimay
        • 11
        In the menu there is a setting when I go to Setting there prompt me a password so what is that pwd for the setting in the menu image.
        The image is download here and is for DM500C
        Thank you
        Regards,
        Phimay
        • Swiftie
          • 141
          Thank you
          Regards,
          Phimay
          I can only think that you're using anotehr user's full image backup. So you will have to try and you can contact that user to find out what the password for the image is.
          E Pluribus Unum
          From the one to whom much has been entrusted, even more will be demanded!
          If you have received help from this post, press the "THANKS" button to show your appreciation.
