Just out the box - please help
  • caveman_nige
    • Feb 2008
    • 4920
    #16
    you could use a serial to usb adapter to connect you cable to your pc, would have been cheaper, but can be similar hassle, but less hassle i think..
    <--caveman_nige added 4 Minutes and 59 Seconds later...-->
    for ftp flashing try this
    Guide: How to use FlashFXP to FTP to your Dreambox
    • mysterons
      • 33
      #17
      can you flash dkv1 onto the dreambox with flashftp? through lan
      • Digger
        • 154
        #18
        maybe buy a serial to usb adapter, may find that easier to use, only a suggestion, worth a try....
        • pawcook
          • 18
          #19
          Is there any reason you are not using the ethernet (network) port? That would be much easier and quicker.
          • westkill
            • 2378
            #20
            maybe you could try the telnet option [in the stickys]
            if you can ftp to your box
            nothing to lose if it goes tits up , till you sort out dreamup
            • mysterons
              • 33
              #21
              Hi Guys,
              loaded and booted up the dreambox to get the ip to use ftp, worked no problem can see all files. The image which is on the dreambox is the gemini project? how do I change this to use digital kaos v_1, sorry for my newbie dumbness!
              • westkill
                • 2378
                #22
                hi m8 did you read the sticky Guide: Flash and Backup an Image via Telnet
                • mysterons
                  • 33
                  #23
                  Sorry not yet im looking for any sort of ftv channels using the gemmeni image just to see if it would pick up anything, will read it now again all advice is great
                  • westkill
                    • 2378
                    #24
                    like you say if you want use gemini
                    we should be able to get it going
                    • mysterons
                      • 33
                      #25
                      ok to pm westkill?
                      <--mysterons added 8 Minutes and 23 Seconds later...-->
                      Im a bit worried as ive tried manual & automatic and its not picking up anything must be doing something wrong
                      <--mysterons added 29 Minutes and 2 Seconds later...-->
                      Scanning now westkill thanks again for your help, now ready for the next stage!
                      • westkill
                        • 2378
                        #26
                        no problem
                        <--westkill added 14 Minutes and 51 Seconds later...-->
                        look here
                        at post 19
                        download from here
                        DM7025 Newbie help - Page 2
                        • mysterons
                          • 33
                          #27
                          Got the cams and ftp'ed the keys and scce files but how do you press blue on the encrypted channel if its not listed?
                          Cheers
                          • westkill
                            • 2378
                            #28
                            reboot the box first
                            what cams have you got
                            realy you need evocamd ,put it on a encypted channel via all services red button
                            ive not got a dm500 any more or gemini
                            so i think you press the blue button highlight the cam you want to use then it should say start restart cam or something
                            then wait a couple of minutes
                            • mysterons
                              • 33
                              #29
                              right so nearly there, is it evocamd 2.17 and say one of the movies channels..press blue start this cam and wait a while, also just to make sure the keys and scce folders were ok just to drop in the var Dir or do they need to be pasted into another folder?
                              Listen man thanks for your help again!!
                              • westkill
                                • 2378
                                #30
                                evocamd 2.17 works for some and not for others
                                yes so do what you said on a movie or sports channel and restart cam and wait a few minutes and see if it kicks in
