uploader is not working error messege appearing
Uploader not working help
try using dcc just make sure you put the correct ip adders in for your rooter dreambox and pc.then ftp the files over if you are still having problems swtich your firewall off while you try it if it then works reconfiger you firewall rembering to switch your firewll back on.also some rooter have firewall built inIf you tremble with indignation at every injustice then you are a comrade of mineComment
