STILL can't get 7025 clearing :(
  • MrFug
    • 880
    DM7025 STILL can't get 7025 clearing :(
    Hey guys I'm at the end of my tether with this...
    I have a 7025+ and I'm in N Ireland. This is what I have done...
    1) Downloaded the file 'Dreambox stuff' containing a keys folder from the forum
    3) Replaced var/keys, and var/scce with the folders from that file
    4) Made sure the files were chmod to 755.
    5) Restart the box
    6) Left of Sly Sports 1
    Yet nothing clears for me. Please can someone advise?
    Thanks.
  • westkill
    • 2378
    what image are you using m8
    you need evocamd as well
    • spants
      • 11
      also having trouble...
      ...on a 7025 twin cable box
      I have mgcam 1.3 on the box - it decodes but stutters on living+1 and a few other channels. snr=93%, agc=43% and ber=0 (I have a great yellow brick booster). Checked connectors etc.
      I would like to get evocam 2.12 installed and working to cure the stutter.
      I have copied roms, keys etc across into
      \usr\keys
      \usr\scce
      \etc\tuxbox\scce
      I have also set perms up at 777 to cover all options
      mgcam works fine (apart from stutter) but evocamd says its running but never clears. Sometimes the sound comes through though (left over key?)!.
      any thoughts how I can make this work? Current image is jade but have tried most of the others out there as well.
      regards
      Spants
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        In some areas evocamd just won't work, not sure why.
        I assume you've downloaded evocamd from the addons menu within the Jade image? Evocamd uses different files than mgcamd does, are you sure you have the correct files? The latest versions of evocamd require additional files before it will work, i.e. faynman.cfg and newcamd-client.txt. I've attached them if you want to add them to the keys folder.
        If you've managed to install evocamd 2.12 then you won't need these files.
        • spants
          • 11
          thanks devilfish.
          I do have those files already and my dm600 (evocamd) and DBOX are working fine!
          (I cant download due to insufficent postings I believe)
          Im sure that I'm missing something simple but not sure what!
          regards
          Spants
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            I mean download from your 7025 using the remote and addons menu.
            Although your Dm600 and dbox are working with evocamd, the 7025 is a different version of enigma and the version of evocamd that you have on the 600 and dbox won't work with the 7025. That's why I suggested downloading it on the box, so that you know it's the correct version.
            Enigma1 images, i.e. Dm500, 600, 7000, use evocamd.pps files. Enigma2 images, i.e. 7025, 800, uses evocamd.mips files.
            I've attached the 7025 version of evocamd_2.17a for you to try if you can't download it on the box, simply overwrite the version that you have, remember to rename this file exactly as the original.
            • westkill
              • 2378
              i didnt get on with the jade image on my 600 or 7025
              i didnt find very user friendly
              i have evocamd 2.12 working even 2.11 or2.13 should do the job
              i have 2.12 working on all the lt team images,gemini 3.50 and 3.60
              2.12 is not on the addon server , i added mine manually, downloaded from there sites
              before you reinstall your keys and scce files to/usr/
              look in var/ as they are symlinked delete them from there as well
              i had it once before when nothin cleared
              • zaf786
                • 327
                \usr\keys
                \usr\scce
                \etc\tuxbox\scce
                regards
                Spants
                Hi download evocamd from your image and copy this evocamd in usr/bin and chmodd 755 and restart your box make sure you put your k*ys and r*ms usr/k*ys and var/scce r*ms
                • spants
                  • 11
                  still cant download from the forum:
                  spants, you do not have permission to access this page. This could be due to one of several reasons:
                  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
                  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. Check your registered email address for an activation link.
                  3. If you are trying to download files from the download section or download attachments, you are required to post on the forums before gaining access.
                  pity the reps from digitalw dont come across ;-)
                  devilfish: I did install via the addon server but same probs n- no worky
                  westkill: Will check later, thanks for info.
                  zaf: thanks - will try later
                  Otherwise, is there a uk setup image with evocamd working for 7025 that I can install?. (pm would be great rather than posting here)
                  regards
                  Spants
                  ex-tw, 6952 area
                  • Devilfish
                    Administrator
                    • Feb 2008
                    • 7872
                    5 posts before you can download, as your welcome PM and email states.
                    Why would any other forums perks or status count here?
                    • zaf786
                      • 327
                      regards
                      Spants
                      ex-tw, 6952 area
                      Do what i said the evocamd version from there server dosen,t clear channels if you replace the evocamd in usr/bin with the one i posted it will work if you cant download evocamd of there image then do this put evocamd in usr/bin the one in my previous post chmodd 755 then goto etc/plimgr/cams and put this in cams then restart box and then go to cam window and restart cam
                      • spants
                        • 11
                        thanks for the clarification on the number of posts required. I used to be an active member of the other board but I am sure that I will be at the required level soon.
                        cheers
                        Spants
                        <--spants added 44 Minutes and 47 Seconds later...-->
                        it is clearing now with these files. The existing files in etc/plimgr/cams were set to 644 for small evocamd file - i changed this to 755 on the new file.
                        so thanks guys for all your help!.
                        Still a little pause happening now and again but much better
                        • zaf786
                          • 327
                          cheers
                          Spants
                          Good to hear you are sorted
