Channel listing layout
  • AirShowNut
    • 329
    DM500 Channel listing layout
    Hi all.
    I have an odd problem that i hope someone can help me with.
    Normally on my DM500C,when i press the centre "OK" button and go into one of the boquets i have a channel name on the left and to the right of the name in brackets is the name of the programme currently on air.
    About four days ago this all altered,on it's own with no intervention from me or my wife or my son.
    Namely when pressing the centre "OK" button and then entering one of the bouquets all we get on screen is a full alphabetical list of the boquet contents and that is it.Nothing in brackets at the side,just a list of channels,also the font size has decreased and all the boquets now fit on the one screen,whereas before they took up two "pages".
    I would like the view back as i was as i find it a pain having to go through each and every channel just to highlight in the info bar what is currently on air.
    As i said i hope someone can help with this,or at least explain how/why the listing view changed like it did.
    Thanks for reading and for any suggestions.
  • Curious123
    • 2591
    Connect to your box using the web interface and then use the web remote to change your settings. If you press the 'video' on the web remote you should be able to change the view.
    • AirShowNut
      • 329
      Thanks for the reply Curious 123.
      Although i have done flashing of these boxes and upgrading of keys etc i'm a bit lost as to what you mean by "web interface"
      Also on my remote control i do not have a button marked "video".
      Thanks again.
      • Curious123
        • 2591
        Thanks again.
        On your pc open your web browser and type in the ip address of your dreambox. Look for something like 'Box control' once you have managed to connect to your box with the browser and try and find remote.
        • westkill
          • 2378
          been a while since i used one of these in the channel list mode can u noy press menu button then option for alternative layout
          cant rember
          or in all channel press the blue for bouquets
          i think
          could be wrong
          • Curious123
            • 2591
            cant rember
            i think
            could be wrong
            On the dm600 remote you just use video button and it changes the layout but there is no video button on the dm500 remote so you have to use web remote.
            • AirShowNut
              • 329
              Cheers Curious123.i'll give it a try.
              • AirShowNut
                • 329
                Tried to connect via crossover cable from box to laptop but web browser wont open the requested page ?
                My box is showing an IP of 82.28.237.201 which is 1 away from the lappy ip but i get nothing just "Problem Loading Page" in my web browser.Am i doing something wrong or have i missed a step out ? Any more assistance greatly appreciated.
                • Curious123
                  • 2591
                  In the dreambox network settings do you a have a gateway configured?
                  • AirShowNut
                    • 329
                    Gateway is listed as 82.28.237.200
                    • Curious123
                      • 2591
                      You could try changing the network settings from DHCP to manual and add the address as it is but change the gateway address to 82.28.237.1
                      • AirShowNut
                        • 329
                        DHCP is unticked,but i will try altering to 82.28.237.1 as you suggest and give it a try.I'll post later with the result,thanks again.
                        • Curious123
                          • 2591
                          You may need to do the same on your pc.
                          • AirShowNut
                            • 329
                            Nada,Nothing,Zero,Zilch - Same result,a blank web page.
                            And get this when i typed 82.28.237.200 in the address bar i got my router logon page,strange as my router used to be 192.168.0.1 What the heck is going on ?!?!?!?!
                            • Curious123
                              • 2591
                              I am confused but if you have router then why not connect with a straight ethernet cable through your router instead of the crossover cable? Also if you have a router then you can assign an static ip address to your dreambox so you always know what the ip address is on the box.
