USB to RS232 Serial Null Modem Cable COM DB 9 Pin Lead
Additional Information
With DB9 cables you will no longer sacrifice convenience when it comes to the placementof computer peripherals in your work area! Let us give you the flexibility to add an existing piece of hardware whenever you need it. Our DB9 extension cables can convert your existing connections or replace the cables that restrict you. Each extension cable comes fully shielded to prevent against unwanted EMI/RFI interference, and its fully-molded design delivers excellent strain relief.
This cable can be used to update Satellite/Cable Receivers from your PC (please check your instructions to make sure this is the correct cable). Suitable Suitable for EuroVox, Dreambox, Technomate, Humax, EchoStar, Manhattan and other receivers with serial ports. If your receiver has a 9pin socket on it, then this cable should work great.
Features
This excellent USB to Serial adapter cable converts standard USB port to DB9 serial port. Great for serial devices that you want to convert to USB. Creates a perfect solution for laptops that does not have serial port and establishes a bridge between the serial device to the computer USB port.
Features:
Requirements:
Package Contents
1 x DB9 Female to Female 6ft Cable
1 x USB to DB9 Serial Port Adapter Cable
**BRAND NEW**
This adapter is designed for ideal connections to almost any serial device such as GPS Navigation kits, Cellular Phones, MP3 players, Digital Cameras, Satellite boxes, Modems or ISDN terminal adapters with over 1Mbps data transfer rate.
Ideal for newer laptops which have a USB port but do not have a serial port.
Features
- Connectors: DB9 Female to DB9 Female
- Used to convert an existing DB9 M/M cable
- Fully shielded to prevent unwanted EMI/RFI interference
- Fully molded connectors with thumbscrews provide you with a quick and easy connection every time
- All lines wired straight through
Features:
- Converts a standard USB to 9-pin serial port
- USB Specification v1.1 & 2.0 Compliant
- Supports the RS 232 Serial interface (standard 9-pin serial)
- Supports automatic handshake mode
- USB full speed communication and Bus Powered
- Single Cable USB to Serial communication
- Supports over 1Mbps data transfer rate
Requirements:
- Windows 98/2000/ME/XP. (Note: Win98 may require latest updates)
- Available USB port.
Package Contents
Keep dreamin'
how the devil are ya
