NTL MMDS
  • fintannl
    • 60
    NTL MMDS
    Hi all,
    I have a DM500C on NTL MMDS Ireland. I have EVOCAMD active and I have what I thought was the correct keylist.txt. I did update the 5401 key which I found on the TCB toolbar. However still no luck. This leads me to think that the 5401 is for NTL cable and NTL MMDS uses a different key. Can someone please confirm what key NTL MMDS uses and point me in the direction of a current keylist.txt for Evocamd or softcam.key for mgcamd. I really would appreciate any help as I cannot understand why I cannot open even RTE2. I can see RTE1 but that is freeview anyway
  • despdan
    • 544
    I think ntl mmds has gone nagra3 so you wont get much but you might get some channels if you use ire fix mgcamd.
    • fintannl
      • 60
      NTL MMDS Ireland
      Thanks, have searched around for N2 fix and have downloaded three hypercam files that go into /var/bin. Is this the fix and do you know what these files do. Thanks again
      • mini
        • 602
        There is no fix for N3 at moment most if not all of ireland is N3 now
        • dubman1
          • 9
          Hi Fintannl,
          I had same prob last night . see my post "more channels gone ireland - help "
          Im running DK image with hypercmd v1.06. on dublin cable network
          i had to power off and reboot the dm500c and manually start hypercmd using tuxbox ( yellow key on remote) the missing channels came back eventually... i seems there might have been a keyroll yesterday morning.
          RTE2 UTV etc are now back and running again.
          • dubman1
            • 9
            by the way mini not all channels in ireland are gone to N3. there are still a few that are listed using 1801h and 1802h in the stream information.
            only channels listed with 1802h only are gone .. i.e n3
            cheers
            • jackandgill
              • 15
              just a quick question if you have a DM500C box is that for cable and not mmds ie DM500t
              • cgscott
                • 3513
                Quick answer - Yes
                Patience is a virtue.
                • fintannl
                  • 60
                  Thanks for all the help guys. The reason I ask about MMDS Ireland NThell is because I am currently trying to set a friend up on this system using a DM500C. I have a Gemini image, have loaded all updated ROM files, have keys setup I think correctly and have both MGCAMD and EVOCAMD loaded. Yet I get no joy. As far as I'm concerned I have the system setup exactly the same way as my own (which is on Corus MMDS and works just peachy) othere than obviously I have to use cables.xml rather than terrestrial.xml. Is there something glaring I am missing. Why would I need a hypercam fix when I am using MGCAMD/EVOCAMD. I know I am close. Am I using the wrong keys. They are the ones on the TCB toolbar so I figure they must be ok. I'm close but no cigar at the moment
                  • jackandgill
                    • 15
                    so have you cable in your house or have you an aerial connected to the box ?|
                    • jackandgill
                      • 15
                      did you turn on au
                      • fintannl
                        • 60
                        au on, mmds aerial
                        • jackandgill
                          • 15
                          if you have a DM500C box this will not work with mmds you need a DM500t box
                          • fintannl
                            • 60
                            The 500C works with NTL MMDS, the 500T works with Chorus MMDS
                            • jackandgill
                              • 15
                              dont think it does
                              a DM500C is for cable and the DM500t is for terrestriel ie mmds no mather what part of the country your in .
