NTL MMDS
You need the fix because the nthell mmds is using nagra2/3 & your chorus mmds is still using nagra1. What your trying to do is get the last channels on nagra2, I would use either mgcamd ire fix or rqcamd I found hypercam a bit ifee.Comment
As of yesterday have most of the channels on Nthell MMDS in Ireland migrated to N3 as per it's cable system in both ex Nthell and ex chor&s areas?
AFAIK Chor&s MMDS is the only one still simulcasting for now.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Thanks guys,
Luckily I have chor$s mmds myself so I'm still happy. However I have being trying to set up friend on Nthell MMDS as that is what is available in his area in Galway. Dan, do you have a link to the mgcamd ire fix as I can't seem to locate in the usual locations
Thanks,Comment
