DM800 Keys
  • stevec
    • Oct 2008
    DM800 Keys
    Hi Guys
    Can anyone point me in the right direction for DM800 keys for virgin?
  • southpaw
    • 2233
    Bigmaq toolbar , BigMAQ.co.uk | All Things Good and FREE!!!
    • stevec
      • Oct 2008
      i got the key files but what cam should i use?
      • southpaw
        • 2233
        personally i`m using mgcam , newcs ,
        • stevec
          • Oct 2008
          is there any images for clones that come with the keys and everything ready to go?
          • southpaw
            • 2233
            Bonseys image does , but depends on your bootloader version , if its a new one it prob bl75 , in which case dont use bonesys image as thats bl72,
            if your struggling mate , drop me a pm with your email address , and i will send you config file ,
            I was in same boat couple of weeks ago and a kind member did same for me ,
            presume your ok with ftp`ing , as you will need to be .
            • Bonesy
              • 655
              seems a lot of confusion out there about 2nd stage bootloaders.
              If your dm800 came with bootloader 75, there is nothing to stop you from still flashing BL69 or BL72.
              Or indeed, nothing to stop you flashing my image which is for bl72, then if you really want to flash it with bl75 afterwords, it will still work....
              • southpaw
                • 2233
                Thanks Bonesy , and Sorry for the incorrect advice , i have a bl75 800 , but your original image gave me "no ca" error , just presumed it wasn`t compat with bl75 ,
                • Scotster
                  • 128
                  That has to do with the backups that the backup program takes. I'm pretty sure it misses out the bootloader completely (seperate bin file). Anytime I have installed a backup I have gotten the CA error. I just flash the bootloader with dreamup and the job is done, takes 2 seconds.
