disable password
  • sabb
    • 31
    disable password
    Hi, i got db500c and i forgot my parental password and want to remove password by without reflashing the box again, is it possible to do?
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    It's possible if you can ftp to the box or if you have the tuxbox commander plugin in your image.
    FTP to /var/tuxbox/config/enigma and find a file called 'config'.
    Right click it and select 'view'.
    Look for a line like...
    parentallock=00000000
    Open up your windows calculator and go to scientific mode.
    Click on the HEX button.
    Enter in the last 4 characters in the parental lock line in the config file.
    Click the DEC button.
    This is your 4 digit pin code. You can then use it to disable the parental lock or Setup lock on your image.
    • dctyper
      • 2539
      or factory reset
