Channels not working (Commando)
  • wo0t
    • 21
    Hello,
    After getting the dust off my dbox2, i uploaded the new commando image, and then the Magic files.
    It seems after both a brute scan and fast scan, only channel 4/bbc seems to work, the rest do not.
    Am i missing something here?
    Did you chmod 755 the files ?
    • wo0t
      • 21
      THe magic files?
      Yes, all have been set to 755, and have double checked them.
      Still 755.
        Hmm. Have you set your location and tried scanning
        • wo0t
          • 21
          Hello,
          Yes, set it to the correct details, and set on scan, with auto scan off. but still same problem, not sure what the problem is now.
          • wo0t
            • 21
            Update:
            used Cardiff NTL, 00004 755000 6887
            • wo0t
              • 21
              MOD:
              Sorry wrong section,
              Could you move to DBOX2 Section please?
              • smoggie
                • 863
                if its commando image try the real magic files from here Dbox
                • maxwii
                  can you post the log
                  • wo0t
                    • 21
                    maxwii// How do i post logs? How could i access them? via ftp?
                    smoggie// Those are the files which i already downloaded and used the "real" magic files.
                    here is a step my step of what i have done.
                    Got old box and put network cable in to connect to network
                    Uploaded commando to /tmp folder
                    flashed without bootloader
                    started up fine
                    uploaded the 2 magic files in the /var/bin/emu and various to /var/keys folder.
                    set chmod to 755 on 2 files.
                    pressed blue button then dbox and set both to on
                    set my detailed for scanning to cardiff.
                    done a scan
                    only fta showing.
                    Did i miss something ?! maybe i need to do something before flashing commando image?
                    • wo0t
                      • 21
                      Just to add more issues, I dont have a serial null modem cable. So cant get botlog and also have a mac, so most applications are windows based
                      • wo0t
                        • 21
                        Update:
                        I deleted the keylist.txt file and i thought with rebooting the box it should recreate the file, but it didnt!
                        i also noticed on the original file, it wasn't modified. Maybe this is the issue?
                        I chmod'ed those files to 755 just incase as well but no luck!
                        I read something about updating the "roms" but i assumed the magic files had the latest roms?
                        • smoggie
                          • 863
                          did your magic files contain 3 folders?? 1). lib 2). var_bin_emu 3). var_keys http://www.mercs.us/Tools.htm
                          • wo0t
                            • 21
                            smoggie//
                            Yes it is, 3 folders.
