Removed Service
  • Celtic67
    • 8
    Removed Service
    Thanks to some useful info on here, I was able to get my DM500C flashed with DW 2.1, scanned channels & things were working.
    Not all channels were found & I'd have to create bouquets so I thought the easiest thing would be to transfer my Dbox files using Devlifish's guide here:
    Guide: Converting Dbox2 Neutrino Services to Dreambox Enigma Services
    Now, I did a search & didn't see anyone mentioning a fix to this, so I hope I'm not covering old ground. Apologies if this has already been covered.
    When I went to the bouquets, they were all listed as Removed Service & had no channels.
    After a bit of checking the files, etc, I found that Bouquetter had created userbouquets.tv.epl with sections such as:
    #SERVICE: 4097:7:0:4c292:0:0:0:0:0:0:/var/tuxbox/config/enigma/userbouquet.4c292.tv
    #TYPE 16385
    The guide says to:
    Using your FTP client, ftp the userbouquet files to /var/tuxbox/config/enigma/cable on your box.
    This leaves the software looking for the .tv files in the wrong place.
    I edited userbouquets.tv.epl and changed the paths to include cable. I guess moving the .tv files up a level would also fix the problem.
    #SERVICE: 4097:7:0:4c292:0:0:0:0:0:0:/var/tuxbox/config/enigma/cable/userbouquet.4c292.tv
    #TYPE 16385
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Thanks Celtic67, I'll edit the guide to reflect your findings.
    Now you're up and running you can try the DK V1 image from here.
    • Celtic67
      • 8
      I'll be doing that this weekend, thanks. I want to find out how it works, not just watch TV on it. Showing a working box to the missus does help justify me spending money though! :girlshit:
