DREAMBOX 800c
  • Prendy
    • 44
    DM800 DREAMBOX 800c
    Really hope someone can help?
    I have flashed the box, but cannot get any further, "Hardware not verified," and in Tuner status, it says "None,"
    Cannot get any further, and have tried different images,I get
    the same messages with them all. Any help, appreciated!
  • caveman_nige
    • Feb 2008
    • 4920
    what images have you tried so far? Is this box a clone?
    • Bonesy
      • 655
      This box is obviously a clone and the image you have flashed is not for clones.
      Be sure to flash a clone dm800 image.
      • Prendy
        • 44
        Dreambox Clone?
        Hya, thanks for the replies, I don't know for sure if it is a clone.
        I have found out from other sources that a batch of boxes have come out of China with tuners that do not work. Which would seem to be the case with mine as,
        1. First message on screen is "Hardware not verified."
        2. Then further into the menu, "Tuner Empty."
        With no options at all to scan.
        I will try and put a cloned image on the box, if you can point me to one that definately works on other cloned boxes.
        I have tried 4 images , with the same reult, the images were
        ones recommended, Gemini2 etc.
        Also this box is Cable and not Satellite, 800HD.
        Thanks again.
        • Prendy
          • 44
          Nearly There.
          O.K.
          I hope you can help me (Bonesy)The box was a clone and
          I have done all you have said,I have flashed a clone image, (Nabilosat Black Hole V0.12) I have installed a new tuner to the box, (800HD. Cablebox.) and it was recognised straight away,the original was duff, I inputted my Frequency and scanned, and up it came with loads of T.V. channels.However, just the F.T.A. are showing, so can anyone tell me how I get the other good channells to work? I am nearly there but just can't seem to fathom the last hurdle.Is there something I need to download to get it done.
          Any help appreciated.
          • Bonesy
            • 655
            You need to ftp accross the "magic" files take look here:
            • Prendy
              • 44
              No Luck!
              Downloaded the files, keys and scce, ftp keys to keys folder, and scce
              to scce folder, rebooted no change anywhere, still got F.T.A. but
              no others to view but plenty of black, blank screens.
              Is there anything else, I can do.
              Thanks for taking the time.
              • Bonesy
                • 655
                What image are you using?
                You stated in setup it didnt show any tuner in it? is that still the same?
                • Prendy
                  • 44
                  Image.
                  Thanks once again for replying,
                  The clone image that you recommended, I could not get to work,as every time it got to the end of flashing I got the message "Failed."
                  After trying a couple of times without success, I managed to flash another clone image, Nabilosat BlackHole V0. 12
                  The original tuner on the cloned box was not working and I ordered another one,replacing the old one, the new one was recognised straight away, and I thought I had cracked it, however I got "the autoupdate keys" you pointed me to and installed them in the keys and scce folders respectively, booted up and tuned to S*y S***s 1, for 10 mins but without any result.
                  I really am gratefull for all your help, and now feel a bit of a nuiscence, and just wish I could get this box to work.
                  • dctyper
                    • 2539
                    put them in usr/scce and usr/keys
                    • despdan
                      • 544
                      You migh want to start the cam or download one if none installed.
                      • Prendy
                        • 44
                        Tried and Failed.
                        Tried the user/scce and user/keys, thanks dctyper,
                        But still nothing happening.
                        Maybe need to start from scratch, as I have swapped so many files around, keys, user, scce, to different folders, maybe
                        confusing everything?
                        Any ideas welcome.
                        • Scotster
                          • 128
                          You need to download a cam. MGCam I find works just dandy.
                          • Prendy
                            • 44
                            Mgcam
                            Thanks Scotster,
                            I have used in the past week a mgcamd, 18/12/08.
                            Would this mgcamd be the same as Mgcam, or are the two
                            different apps. Also is the one I have used out of date?
                            If so, can you point me to latest Mgcam.
                            • dctyper
                              • 2539
                              right, download the latest cam as mention above. clear out the folders var/keys and var/scce and put the special keys/roms in usr.keys and usr/scce restart the cam by bressing the blue button then press left or right untill you see the cam. press ok to start it. and bam. free ~~~~
