channels missing
  • stetski
    DM500 channels missing
    hello,
    new to the dreambox stuff, i have flashed it with v1.1 as this looks to be the best going by posts, i can get some of the channels but more are missing, i have tried re-scanning to no avail. any ideas
  • mini
    • 602
    you may need to try a booster as they have weak tuners. Or you can try connecting the box tthe cable connection coming direct from outside without any splitters.
    • kris9000
      • Apr 2009
      • 121
      Which channels are missing? Also, what scan did you do - was it a brute force?
      • alexh
        • 225
        An automatic scan is only as good as the cables.xml file included in your image.
        Brute Force is not an exhaustive algorithmic scan as it sounds. It is just a list of frequencies & symbol rates. If a frequency/symbol rate pair is missing from the bruteforce section of your cables.xml you will never find the channels on that transponder.
        What you can do is add all your favourite channels into bouquets. These are permanent record of channels you have found. Once you have done that you can try a network scan. This uses information contained in the over-air transmission to find more channels.
        On Enigma based images (such as DK1.1) you go to a working channel and press:
        Menu->Setup->Service Searching->Manual Transponder Scan
        Select the "network search" option and then press green (start scan) and sit back.
        All Enigma based images I've used have a few bugs in them WRT scanning on UK cable networks because VM are a closed network and do not 100% follow the specs.
        Following a network search it makes sense to look at the top of the "all channels" list and select any strange named channels (perhaps named SID 0x958 or similar). Leave it on that channel for a few minutes (even if they are blank) then opening the all services list once more and one by one they will be correctly identified as TV channels.
        If after a search a channel you used to have has been lost, go the the bouquet entry. It will be listed as (service removed). Select it and within a few minutes of being on that channel the software will read the network information for that transponder and find all the channels on that transponder and update the "all services" list.
        Once finished check your "all channels" list against the VM list of all channels to make sure you're not missing any.
        http://en.wikipedia.org/wiki/List_of...s_on_Virgin_TV
        Using a mixture of manual transponder scan with "network search" and bouquets I am able to maintain a full list of all channels.
        • stetski
          hello, the channels that i have are in the main, the old terrestrial channels. i am very close to the cabiner and therefore think that the signal if anything would be on the high side rather than low, suppose i could attenuate it down (worth a go). the scan i did was by selecting area's that mine could be... warrington, liverpool, manchester, all appear to have the same issue but the frequency plans does seem to be a valid point. many thanks for the quick reply's, i am going to try what Alexh suggests (will take time to read a few times, haha). thanks again, will let you know how i get on.
          • mad_wizard
            • 11
            Hey first thanks to all the memers here for excellent info on the site, its a leraners dream!!
            Anyways I need litte help, I have a Dreambox 500C and have followed all the tutorials, I have flashed the image, ftp'ed the images, then chosen bruteforce UK to scan
            and the box works and picks up all the channels and their programme schedules but only bbc1/2, itv, channel4 and channel5 work, can someone help me please..
            • kris9000
              • Apr 2009
              • 121
              When you say ftp'ed the images, do you mean put the image on with dreamup and ftp'ed the keys?
              • kPATm
                • Aug 2009
                • 12
                [QUOTE=mad_wizard;403280]Hey first thanks to all the memers here for excellent info on the site, its a leraners dream!!
                and the box works and picks up all the channels and their programme schedules but only bbc1/2, itv, channel4 and channel5 work, can someone help me please..[/QUOTE
                I have just updated my EuroVox Ultra with the DK v 1.1 image and I can only see the normal channels aswell.But I have the listing for all the channels but the ones I cant view have a key next to them.I ftp'd the keys and scce files to their proper folders(I think).I read a tutorial and in it on one of the images it shows the files being ftp'd into /var_init/ but when I use flashFXP i cannot transfer files to her I have to put them in /var/ (without the init)Any help please.
                  What area are you in m8 ? If your in Leeds they have gone and theres no fix. Not now and not in the foreseable future.
                  • kPATm
                    • Aug 2009
                    • 12
                    Im in Greenock just outside glasgow
                    • kPATm
                      • Aug 2009
                      • 12
                      Ah got it working I used the DreamBox update fixes from the BigMaq toolbar.
