How Do I Setup A Mount for Direct Recording?
This guide will outline how to setup mounts for direct recording.
We will assume that the dreambox is setup and you are able to connect via FTP/Telnet and can access the web interface.
Whether we are mounting to a PC or a NAS, we will need a shared folder to record to. For
The Dreambox will only play mpeg movies. Copy the movie to the shared folder once the mount is working and you will be able to access the movies using File Mode on the dreambox.
Alternatively, if you want to play avi/divx files, you can stream using VLC. VLC transcodes the avi to mpeg on the fly before streaming to the dreambox. It's not the ideal solution and doesn't work 100% but it's usually watchable.
