You need to make sure you download the Sqlite EPG plugin and that should download the Radio times file to your dreambox. In the original instruction written by wizbit77 you needed to go to the Radio times web site and download the dat file as the one on the Pli image was corrupt at the time but I think has now been corrected by the pli team.
download this file http://xmltv.radiotimes.com/xmltv/channels.dat
copy it to /var/tuxbox/config/dbepg/ and overwrite the existing channels.dat file
now go and map your new channels as normal.
14 days EPG for 600PVR
1st you need hdd installed to store epg data!!
2nd your box connected to the internet !! (doesn?t have to b all the time, just for downloading epg data etc..)
3rd ftp program to upload files. (only in setting up)
4th setup your bouquets favourites etc?(prob have done this already)
Ok set epg to SQLite EPG database go to system settings either (menu, setup, system settings, EPG) or (blue button, dreambox settings, system settings, EPG)
In EPG
Set epg data store: to SQLite database
Set epg location: to Internal harddisk
Epg directory should say /media/hdd
Set epg days to 7 (just example u can change 2 whatever latter)
Press green button to save.
Exit
now go to downloads (blue button, software management, downloads, addons/plugins, Digital+ EPG grabber or Dreambox EPG plugin. (whichever is available to u))
check the download is ok ? (yellow button, plugins, dreambox epg config)
in the config.. package will probably say Digital+ and when dropped down Wolf_nl, & possibly Radio Times as well? we?ll come back to this
Ftp go to directory /etc/tuxbox/dbepg copy Digitsl+.cfg or whatever .cfg files are there 2 a place on your pc (just for backup)
Then delete them from your box.
Download the attachment Radiotimes.zip & unpack the files (rt_uk.cfg rt_uk.sh)
Now ftp the attached file rt_uk.cfg to /etc/tuxbox/dbepg
Now ftp the other file rt_uk.sh to /var/bin
Exit ftp
Now in tv mode select your Bouquet you want times epg 4
Select a channel (any one as long as your in the bouquet)
Now back to dreambox epg config (yellow button, plugins, dreambox epg config)
in the config.. package it should only say Radiotimes UK now as you got rid of the other crap ha ha
set time offset to 0 hours
number day 7
Cron options (will check this setup in a min)
Check use cron if you want your box to automatically get epg at time 6:00 (can set it 2 whatever time u want)
Press green button channels:-
On the left side you should have the radiotimes channel list, on the right your bouquet channels.
From the left scroll down to ie? bbc 1 select ? highlite will b a box now & on the right the highlite will appear at the top scroll down to match it with you bouquet channel
Continue till you have matched all your channels.
Then press green done. Exit
Back in epg config press yellow retrieve:-
Wait for the retrieving to finish press blue done. And exit menu back to tv
Press red button & hey presto radiotimes epg!! Exit now last bit cron
go to system settings either (menu, setup, system settings) or (blue button, dreambox settings, system settings)
Thanks for that got HD installed, where can I get the cfgs so i can FTP them
bubLeave a comment:
hi curious,where do i download the radiotimes attachment files from,im running the pli jade image and have downloaded the digital + epg grabberLeave a comment:
In EPG
Exit
Exit ftp
number day 7
go to system settings either (menu, setup, system settings) or (blue button, dreambox settings, system settings)Leave a comment:
Im sure I have seen 14 days EPG for the Dreambox 600 which updates EPG through the internet. I have seen this Epg Evolution Project but I think its for the 500c only.
Done a search but cant seem to find it
bub
Leave a comment:
