How do I back up image on PLiJade3
  • freck
    • 1076
    DM500 How do I back up image on PLiJade3
    As it says above guys,I've tried to do this with the back up option in settings and chose /etc to back up image to but it wont do it.
    Any tips or tricks to get this going or do i have to back up to a specific folder.
    Thanks,
    Freck
  • Curious123
    • 2591
    Thanks,
    Freck
    You din't say what sort of a dreambox you had and what sort of backup you were trying to create. I have a dm600 with an internal hdd and I do backup through Menu > Setup > System settings > Backup & Restore > Backup dreambox. This backups up your bouquets cams to your internal hdd. I also create an .nfi image backup on my hdd with a plugin.
    • freck
      • 1076
      Its a dm500s and doesnt have a hdd,I can see the back up and backup restore and asks for a folder to back up to but i dont have a hdd installed as the 500 doesnt take one but when I choose /tmp to backup to it doesnt do it,and my var is only 47% full.
      I want to take the image out via ftp and store on my pc.
      Thanks Curious for the reply.Its mainly the bouquets and services i want out as i've just sorted them and theres a fair lot of channels on them so i dont want to go tru the process of arranging all those again....what you think.
      Freck
      • cgscott
        • 3513
        Just FTP to the box and pull the bouquets and services file from the appropriate folders and a save them on your pc.
        Then you will have them.
        No need to backup full image.
        services - /var/tuxbox/config/enigma
        bouquet - /var/tuxbox/config/enigma/cable
        Patience is a virtue.
        • despdan
          • 544
          For a full backup Image telnet to the box & input:
          cat /dev/mtd/3 > /tmp/backup.img
          wait 20sec then goto your tmp folder & copy the backup.img to your PC
          • crukzet
            • Feb 2010
            • 5
            If you make a backup.img this way, can one use it as a .nfi?
            Or is it another way to restore or duplicate a dreambox with this image? I have tried the eraseall command but it doesn't seem to work with latest PLI firmware.
            • despdan
              • 544
              No they are diff images for diff boxes
              • crukzet
                • Feb 2010
                • 5
                I have two 7025 and one is setup like I want it and I like to do an image of it and restore to the other box.
                As I wrote I made a backup.img with cat /dev/mtd/3 > /tmp/backup.img. But need a way to restore it cause the way with eraseall command doesn't work with the latest PLi it seems and I have no clue how I should do it in another way.
                Do you have a suggestion? I would be real greatful, I sort of hit the brick.
                • Curious123
                  • 2591
                  I don't have a dm7025 but you could try this plugin;
                  • crukzet
                    • Feb 2010
                    • 5
                    Hi again and thank you. I will try the plugin and let you know if it works.
                    • crukzet
                      • Feb 2010
                      • 5
                      Hi again.
                      I tried the following:
                      media/hdd build-nfi-image.sh /media/hdd/backup
                      I get the following reply:
                      -sh: /media/hdd: Permission denied
                      All resources have 777 so it should not be that and I'm logged in as root.
                      Any suggestion would be great.
                      • crukzet
                        • Feb 2010
                        • 5
                        Hi again.
                        Solved it. Had the wrong .sh file and placed the other in the wrong directory. Worked like a charm after that.
                        Thanks for the files.
