dm500 not picking up channels
  • trance
    • Aug 2009
    • 223
    DM500 dm500 not picking up channels
    ok, i apologise in advance for asking this newbee question.
    i have a bit of a problem , to cut a long story short ive been away from home since october.
    i returned home yesterday to see that my d500c is not picking up any channels (some not sky sports or bbc1 but others) what i would like to know is, has there been any new keys since august, as thats when i programmed/flashed the box.
    i have done bruteforce scan but no luck, should i reflash or insert some new keys if there are 'new keys'
    my missus says its been down since mid october
    im using a dm500c
    dk image v1.1
    im in east london
  • Scarface
    • 92
    There have been a few key rolls since October, set you magic files to chmod 777 via FTP and re-scan, should update and auto write the new keys
    • trance
      • Aug 2009
      • 223
      nice 1 scarface, but when you say 'set you magic files to chmod 777 via FTP and re-scan' what exactly do i change in the var/scee files.
      im all good using ftp, so thats not a prob just need a little guidance as to what needs [how] changing
      plus are my old magic files still good or do they need replacing
      thanks mate
      • tomhick024
        • 559
        Right click on files that you have in var etc/scce and then select 'Change attributes'.
        But i think its 755 you change them to when setting up unit!
        Or delete the kxys in folder keylist.txt and rescan for services, then go to sly sps 1 then ssp 2 and wait for it to update
        Whatever!!
        • trance
          • Aug 2009
          • 223
          i'll give it a go later today,
          so i change the attributes to all files in var etc/scce , is it 777 or 755?
          on a side note if i reflashed would i still have to chmod
          nice1 tomhicks024 , i hope your not related to the texan tumour who runs liverpool fc
          • Scarface
            • 92
            Everyone says 755, but i set all mine to 777 and never had a problem, and if you reflashed you would still have to set the attributes, for every keyroll your keylist.txt file wont update unless you have the attribues to read/write. So in future you wont notice any keyrolls.
            • Hazza
              • 61
              This is quite interesting.
              I have just reflashed 2 boxes for a mate and put in k*ys etc. and all attributes are set at 644, and so is mine, which has been working with these settings for months, as do the 2 that I have just done.
              Why does everyone keep saying 755 if other setting work?
              Do we need different settings for different areas?
              I guess with me it is a case of if it aint broke don't fix it.
              Still I would be interested to hear what others have to say.
              Harry
              • trance
                • Aug 2009
                • 223
                do they all have to be on read write owner/group/public im using flash fxp
                cheers
                • trance
                  • Aug 2009
                  • 223
                  ok, so i deleted all my var/keys var/scce files & got some magic files from devilfish link, i put those in var/keys var/scce and changed all the attributes in these files to 755.
                  so i rebooted with no luck, re-scanned with no luck ? do i just reflash the image, or maybe there is another trick
                  when re-scanning shall i delete channels in bouquets?
                  help me out please
                  • Curious123
                    • 2591
                    help me out please
                    You are not in Leeds or ireland by any chance? Did you turn to S*y Sports 1 to see if the channels cleared?
                    • trance
                      • Aug 2009
                      • 223
                      no im east london using a dm500c, i went to sly sports 1 but it never cleared
                      curious123, what are the attributes set to on yours? + do i change the atrributes for only var/keys var/scce, i have changed all them to 755 in both these files
                      • tomhick024
                        • 559
                        When you had files in proper place, did you restart the cam by holding down the info button for about 3 seconds, and then select and restart your cam. then go to ssp1 then ssp 2.!
                        Whatever!!
                        • trance
                          • Aug 2009
                          • 223
                          yep i did this it restarted evocamd 2.12 but it didn't clear the channel
                          • tomhick024
                            • 559
                            Make sure your majic files are the latest available, grab them from the TCB.cc toolbar or Bigmaq toolbars! in the files and fixes tab! (updates and fixes)
                            Whatever!!
                            • trance
                              • Aug 2009
                              • 223
                              sorry to sound lika a div, but what files am i looking for in there
