UPC Nagra3 Card Working in Dreambox but need Help
  • despdan
    • 544
    Hi All
    Am helping another member here & have his upc n3 card working in the dreambox using rqcs:
    Opening sci... Done
    Detecting card... Card present
    root@dm500 ~ # Resetting card... Done
    Identifying card type...
    Historical bytes: D N A S P 1 4 2 R e v G 0 2
    44 4E 41 53 50 31 34 32 20 52 65 76 47 30 32
    Card type: Nagra
    ROM Revision: 142
    EEPROM Revision: RevG02
    Configuring sci...
    SCI | f: 3574595 | T: 1 | ETU: 32 | EGT: 1 | CWT: 25 | BWT: 89291 | WWT: 0
    Slot custom parameters:
    des_key: 0102030405060708091011121314
    box_key: ################
    dt06_key_0d:
    cam_n: ######################## ...
    Long parameter, first 32 characters shown, 128 total.
    secondary_key:
    rsa_key:
    Card start-up initialization...
    Using Plain CAM N session negotiation method:
    Setting Field Size: Done
    Retrieving IRD serial number: ########
    Retrieving CAM serial number: ########
    Retrieving System IDs: 5F01,5F02
    Retrieving CAM challenge data: Done
    Performing Session Key Negotiation: Successful
    Starting card worker thread... Done
    Starting protocol server on port 10000 [newcamd protocol]
    Logical Slot 'Lower' READY!
    Starting Logical Slot 'Upper' [Users: 1]
    Device Path: /dev/sci1 | Listening Port: 10000
    So going by that its reading the card ok, Now i have tried a couple of emu's but not having much luck the best has been mgcamd:
    [mg0] stoping camd..
    /dev/dvb/card0/ca0 error 16: Device or resource busy
    got 52 cmd 9F
    [mg0] namespace FFFF0000 t-id 38 on-id 601
    [mg0] descramble on 1, source 0
    [mg0] service 25A index 0 pmt pid 21 (19)
    ECM: CaID: 0x1802 -> CaPID: 0x0692 ProvID: 000000
    [mg0] network can't decode
    [mg0] pid 0x0692 failed to decode.
    [mgcamd] emm started
    *EMM: CaID: 0x1800 -> CaPID: 0x0080 ProvID: 000000
    *EMM: CaID: 0x1801 -> CaPID: 0x0081 ProvID: 000000
    *EMM: CaID: 0x1802 -> CaPID: 0x0082 ProvID: 000000
    DISCONNECT **** [Wed Jan 20 00:13:40 2010] Client disconnected...
    User: 'dummy' | Current clients: 0
    [newcamd] 127.0.0.1:10000: problem, will try to reconnect
    [newcamd] Connecting to 127.0.0.1:10000...
    [newcamd] Login to 127.0.0.1:10000 as dummy accepted (31ms)
    CONNECT **** [Wed Jan 20 00:13:42 2010] Processing incoming connection...
    User 'dummy' authenticated [Client: unknown] | Clients: 1
    [newcamd] Card data from 127.0.0.1:10000 (34ms):
    Userid 0 caid 1802 providers 2
    Idents: 005F01 005F02
    DATA **** [Wed Jan 20 00:13:42 2010] Processing card data request...
    Username: dummy | Logical slot: 'Lower' | Card data sent successfully.
    DISCONNECT **** [Wed Jan 20 00:14:13 2010] Client disconnected...
    CONNECT **** [Wed Jan 20 00:14:15 2010] Processing incoming connection...
    DATA **** [Wed Jan 20 00:14:15 2010] Processing card data request...
    anyone see something i've missed???
  • 2tone
    • 483
    i see from another post on another forum you have this working good on you m8 all your hard worked payed off
    • despdan
      • 544
      Yeh thanks M8 only a few more grey hairs
      root@dm500 ~ # CONNECT **** [Wed Jan 20 19:01:30 2010] Processing incoming conne
      ction...
      DATA **** [Wed Jan 20 19:01:30 2010] Processing card data request...
      ECM **** [Wed Jan 20 19:01:30 2010] Processing ECM request...
      Username: dummy (1 users) | SID: 0602 | Logical slot: 'Lower'
      Cache: Miss (1 elements) | Card: Valid control words returned. [773ms]
      CW0:CW1 | ################:#############
      ECM **** [Wed Jan 20 19:01:36 2010] Processing ECM request...
      Cache: Miss (2 elements) | Card: Valid control words returned. [763ms]
      CW0:CW1 | ################:################
      • joe6915
        • 10
        Can you explain here how it is done?
        I have gone bald trying to get this working
        • freck
          • 1076
          There's a lot of peeps trying to do this and little have succeeded....well done Despan,could lead to something interesting.
          Freck
          • 2tone
            • 483
            what have you got as in ways of box details
            • hatchet
              • 159
              Well done buddy, any hints ?
              • ram1980
                • Feb 2010
                • 11
                do you get all channels and ppvs
                • despdan
                  • 544
                  You get what ever the sub is paid for & if you pay for ppv
                  • ram1980
                    • Feb 2010
                    • 11
                    no way to descramble it
                    • satman
                      • 736
                      control words are being found,, dan that is close ...
                      have couple things to check now,, i) if CW are inverted this may cause some problems,, ( this was the case with n2 ireland )
                      ii) your actual decoding emu does fully support n3?. what others have you tried?
                      boom!
                      • satman
                        • 736
                        also,, in your cardserver ( rqcs ) is there function to check entitlements of card? can you see all ok entitilements ?
                        boom!
                        • red devil
                          • Oct 2008
                          • 690
                          its a combo of CCcam 213 and rqcs and its reading card, clearing channels and a little bit more
                          • Mooley
                            • 82
                            Have 2 DM's sitting here would love to get up and running again, sounds interesting lads.
                            • satman
                              • 736
                              Good,,, with the logs dan posted, very obvious its close
                              boom!
